Old 02-13-2022, 09:03 AM   #1
3twinridges
3twinridges's Avatar
Default Good quality chassis paint
Starting to think about priming and shooting color on some chassis parts for an F1. I want a matte or satin black not gloss. Looking at the PPG hot rod black or SEM hot rod black kit, they look like good paints. Anybody used anything else that would be a good chassis paint that would hold up over time? This would be for a complete restoration but also a driver.
Starting with springs and shackles, but will move into the frame over the summer.
JB
3twinridges is offline   Reply With Quote
Old 02-13-2022, 09:17 AM   #2
swedishsteel
Default Re: Good quality chassis paint
Sandblasted, dipped, rusty, wire wheeled....?? Surface makes a difference what will last.
swedishsteel is offline   Reply With Quote
Old 02-13-2022, 09:52 AM   #3
3twinridges
Everything will be media blasted including the frame.
JB
Old 02-13-2022, 10:03 AM   #4
Krylon32
Why not powder paint?
Krylon32 is offline   Reply With Quote
Old 02-13-2022, 10:07 AM   #5
3twinridges
I have access to a powder coater here locally, it’s just tough to move everything there and back, especially the frame.
JB
Old 02-13-2022, 10:42 AM   #6
36and63
36and63's Avatar
I've used Eastwood chassis paint on 3 frames and been very pleased with results on all of them.
https://www.eastwood.com/eastwood-or...oss-paint.html
Pat
36and63 is offline   Reply With Quote
Old 02-13-2022, 11:03 AM   #7
Krylon32
I know moving a frame can be difficult. I've had around a dozen frames and suspension components powder coated. I just enlist friends and neighbors to help with the move.
Old 02-13-2022, 01:03 PM   #8
uncle buck
uncle buck's Avatar
“Chassis Saver” semi-gloss black is the best I have found. It is made by Magnet Paints. It will survive being beat with a hammer and fold in half with out chipping or flaking off
uncle buck is offline   Reply With Quote
Old 02-13-2022, 03:08 PM   #9
3twinridges
Thanks bud, my concern on the chassis saver is that it says it’s sensitive to uv light, and over time will shift to charcoal gray. That’s why I was thinking of using a 2K product. I have used por15 brushed on and then sprayed with top coat chassis paint, it looks really good and clean still but that paint is only a few years old.
JB
Old 02-13-2022, 03:12 PM   #10
rhphotord
rhphotord's Avatar
Powder coating great for the frame but then again it's only the frame. Is it a concours restoration? Your call regardless and your wallet. I sprayed Eastwoods frame and chassis paint on my 34 ten years ago and still looks new. Went cheap on my AV8 build and used tractor enamel brush and roller application. Went that way on my traditional hot rod AV8 roadster figuring that's how the post WWII guys would have had to do it. Thinned correctly it really looks good. No right answer
rhphotord is offline   Reply With Quote
Old 02-13-2022, 03:20 PM   #11
OldGold360
Wurth also make a product similar to POR15 that I’ve used in the past. Spray or brush on. Also, Sherwin Williams makes a product called Polane that is good. It’s available thru their industrial stores. Make sure to use the UV additive though. Regardless of what you use, preparation is everything. I plan to power coat my frame, only because I don’t want to wire wheel it myself and would rather have it media blasted. Might as well have them powder coat it as well.
OldGold360 is offline   Reply With Quote
Old 02-13-2022, 06:07 PM   #12
36coupe
36coupe's Avatar
Some people like JD blitz black, satin. Not UV protected, not sure if that would be a problem on a frame.
36coupe is offline   Reply With Quote
Old 02-13-2022, 09:26 PM   #13
PeteVS
PeteVS's Avatar
Years ago, I had a Ford Ranger pickup. The rear spring shackles had been powder coated. The powder coating kept the moisture inside and the corrosion well hidden until they both snapped.
Old 02-13-2022, 09:35 PM   #14
PeteVS
PeteVS's Avatar
Originally Posted by 3twinridges View Post
It’s just tough to move everything there and back, especially the frame.
JB
Moving the frame from my previous project:
Old 02-13-2022, 09:36 PM   #15
3twinridges
Thanks guys for the feedback. Non of my trucks are concourse, I just want them to look nice, drive them, and especially use our 50 F1 for the farm. I know there are nay sayers to the POR product, but our 52 frame was media cleaned, POR painted with a brush and then sprayed with POR top coat in the windows specified and it looks really nice and is holding up well. The good thing about that, is that I can touch up places, etc with the rattle can of top coat. The products mentioned seem to be about the same, and I am familiar with the POR steps. Appreciate it!
JB
Old 02-13-2022, 09:48 PM   #16
Karl
Karl's Avatar
I've used POR 15 - and carried the evidence on my hands for weeks
POR15 is also sensitive to UV light so does need a topcoat as well.
Also has some isocyanates in it so some care is required -Probably best not to get it all over your skin like I did despite using gloves
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 02-13-2022, 09:49 PM   #17
petehoovie
petehoovie's Avatar
Old 02-13-2022, 10:42 PM   #18
3twinridges
LOL bud! I remember the first (and last) time I treated a gas tank with POR gas tank sealer. I had it everywhere, on the floor of the shop, and on my hands (my nitrile gloves tore). I had to go to work like that, took a week to wear off.
JB
Old 02-13-2022, 10:51 PM   #19
fordor41
fordor41's Avatar
I used Rustoleum satin black(brushed on) on my '41 frame and running gear. after 24 yrs it still looked great. cheap to touch up if needed.
fordor41 is offline   Reply With Quote
Old 02-14-2022, 10:39 AM   #20
36coupe
36coupe's Avatar
For Canadians there is a produce similar to POR15 called DOM16 made by Dominion Sureseal about half the price of POR15
Self levels when painted with a brush
File Type: jpeg 5137D76C-E4FA-4B6F-AEED-12CFA04FF520.jpeg (66.8 KB, 3 views)
