Hi all - my all stock 1935 fordor hesitates/dies in 1st gear when it is cold. I had someone "work" on it and his "solution" was to drive it with the choke 1/3 - 1/2 out until it warms up. That is possible, but it seems to me that it is a workaround and not a fix. Is this normal, or is there something wrong with the carb or fuel pump. When it warms up, it purrs and runs just fine - this only happens when it is first started. Thanks in advance.
Um, that's what chokes are meant to do.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
Well, excuse me for not knowing all the intricacies of it. For your information, I'm used to the choke on the Model A which is used solely for starting.
I was under the impression that this was a forum for guidance and advice about Fords regardless of one's knowledge level. Apparently I was mistaken. |
I think normal. My 48 business coupe requires the choke out for about 3- 5 miles if it's cool outside.
Thank you 1942deluxe - THAT was the kind of answer I was looking for.
@tomcarmen - you are describing exactly what happens. It starts fine. I have experimented with a longer warm up period and it works better. As you say, it runs just fine once fully warmed up, so I will leave well-enough alone and pull out the choke. I just hadn't heard that before because the choke acts differently in the Model A, which I'm more used to. Thank you so much!
I know nothing of Model A's and frankly have very little mechanical knowledge but I tend to go with what works on an otherwise good running engine. Maybe it's just me but I have this thing in my head about driving with any of the choke pulled out, I don't know if it's good, bad or if it doesn't matter. All I know is after a full warm up off I go with no issues. Happy motoring!
Tom |
maybe a little more advance after starting if not sound about right if it drives right after a short warm up it wont hurt it by the way whats the outside temp when this happens it has a big effect on the way they behave
#10 | |
![]() Quote:
As nobody else has as yet said anything, I will. Many of us on the Fordbarn, myself included, tend to insert a bit of humor in our replies. I believe that you misinterpreted FortyNiners' humor as antagonistic, and upped the ante in no uncertain terms. This is our hobby, something we enjoy. Please help us keep it fun! ![]()
Alan |
#11 | |
![]() Quote:
i don,t know what model carburator is on your car.some carbs have a winter & summer knob on the linkage for the fuel plunger check to see if your carb has this. the winter setting giver the pump a longer stroke.witch would help to reduce the stumble
#13 |
On most of the stock carbs on V8s there are three holes to plug the plunger on the accelerator pump into. There is a little link bar yhat you pop out with a flat screw driver. In cold weather choose the one that gives the longest stroke. And in thinking about Model As with their spring loaded choke knob, keep in mind that choke knob does double duty as it is rotated by the operator to enrich the mixture until the engine is warm. My Ford published 'Model A Handbook' says to open it one full turn for starting and warm-up. After the vehicle is warmed and under way it should be rotated clockwise until it is approximately 1/4 turn off it's seat. Just a different way of enriching the mixture.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#14 |
As stated previously.
Don't know what carb. you are using but generally there is a winter setting for the accelerator pump. The farthest hole from the throttle plate shaft center line.
#15 |
A model A has a choke Knob in the form of a needle in the carb end, to start you pull that up opening the needle ,as she fires you turn the knob anty clock wise to richen the mixture .As it warms up you start screwing it in ,its the same deal as a v8 ,Full out to start then 1/2 in etc
#16 |
Ahhhh! I did not know about the Summer/Winter setting on the carb. I will take a look at that and let you know how it works.
Also - when I say cold, I'm talking Southern California cold. So 40s - 50s, but really it has to do more with not starting it for awhile. We don't get into the 10s and 20s here. Thanks again all! |
#17 | |
![]() Quote:
