Old 04-11-2022, 09:18 PM   #1
novaskilling
Default 48-52 F1 pedal bushing issue
i just installed new brass bushings in my 48-52 f1 pedals. I'm having an issue getting the shaft to fit into the bushings now so i can assemble the pedal assembly. Do these require a hone or anything? should it be a very tight fit?
novaskilling is offline   Reply With Quote
Old 04-11-2022, 09:26 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 48-52 F1 pedal bushing issue
After installation, MOST bushings require honing to size...a reasonably snug fit with lubrication. Even a 1/2" wooden dowel with a flap of sandpaper mounted in a drill can be made to work as a hone. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 04-12-2022, 08:21 AM   #3
3twinridges
3twinridges's Avatar
You probably just have some burrs on the edges. I ran a brake hone until the pin fit. Clean the bushing after each hone pass so that you do not go too far and make it loose.
JB
3twinridges is offline   Reply With Quote
Old 04-12-2022, 10:47 AM   #4
tom1948
In the past I have had good luck using a dingleberry hone, just be careful of over honing.
tom1948 is offline   Reply With Quote
Old 04-12-2022, 11:38 AM   #5
supereal
supereal's Avatar
Be sure you have opened the bushings to allow lubrication. Just drill through the grease fitting hole before you reinstall the shaft, using a drill bit small enough to protect the grease fitting threads.
supereal is offline   Reply With Quote
