The fuel pump in my ’37 Ford has a needle valve in it. None of the other fuel pumps that I have seen have this feature. What is the purpose of this?
Thanks, Robert, |
It would be helpful to know "where" on the pump, but if it is external on the side of the upper body with a T handle and a spring on the threaded shank, it's the drain plug.
Thanks David, that's where it is located. I don't see much use for it though. I believe that the pumps sold by the vendors didn't have this feature. I've used at least a half dozen of those over the years and none did. This pump was rebuilt by a reputable rebuilder and I just installed it. I’m confident that it will last for a long time.
It's original purpose was to permit you to drain off sediment trapped by the screen in the upper body of the pump. It was standard equipment on all '32-'34 pumps and was replaced with a special slotted screw with a fiber washer starting with the '34 V8 pumps.
As a side note if that drain valve is not seated and tightened properly the pump will not function. Personally I would not ever open it as it makes a mess of fuel on your intake
