Fenton headers on a 1940 24 stud. One bolt will not thread. I give up. Not my car but doing an engine change for an elderly friend. I spent way too much time trying to get one bolt to thread. The design looks like the designer was on crack. POS Fenton headers they are...
Front bolts are 7/16-16, all the rest are 3/8-16. Welcome to Ford Flatheads.
Alan |
#3 | |
![]() Quote:
This fellow may have a set of off shore knocks off. The instructions should read due to accumulated tolerances some adjustment is required.
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
You are correct. My bad.
Alan |
Ran into the same problem with engine holding [mount] exhaust plate-Some adjustment of holes required Newc
I have a set, bought from a swap meet, but new-ish looking, I assume speedway Chinese mfr, and they fit just fine. Got a rat tail file?
#10 | |
![]() Quote:
Just be sure it's a USA-made rat-tail file! Otherwise, make'm funny holes! DD . |
I’m in before the hammer!
Alan |
