Old 03-13-2022, 01:12 AM   #1
Harold Degand
Default 1932 brake rod length
Hello.
I bought a set of 4 mechanical brake rods for my 32 (missing on the car when I bought it). But they are way to long.
I have a dual shaft system.
I could shortening by myself but I’m not sure of the initial position of the dual shaft.
If someone has the info.
Thanks
File Type: jpg BE540A26-05E8-4F31-87F7-2E95F487A94E.jpg (36.5 KB, 43 views)
Harold Degand is offline   Reply With Quote
Old 03-13-2022, 02:49 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 1932 brake rod length
Originally Posted by Harold Degand View Post
Hello.
Thanks
Old 03-13-2022, 04:05 AM   #3
deuce lover
deuce lover's Avatar
Hello.
Thanks
Harold,Maybe this pic will help.Its an orig '32 Ford French chassis.Sorry I don't have a pic where the rods connect to the backing plates.Remember that 1 set goes to the parking brake and functions with the parking brake handle..That should not be difficult to figure out.Your pic was to dark so I edited it .
Old 03-13-2022, 04:20 AM   #4
DavidG
DavidG's Avatar
While not entirely evident from your photo, I am assuming that your car is left-hand-drive and uses four brake rods, one for each wheel (and not the more complex six-rod configuration with two rods for each rear wheel).
The front rods were originally the same as on North American LHD single cross shaft systems, namely B-2495, 50 7/8" long. The rear rods were unique to two cross shaft systems, namely BF-2499-A, 54 13/16" long. (The rod measurements are from the center of the hole for the clevis pin to the end of the threads on the other end of the brake rod.)
The brakes should be set up so that the arms on the cross shaft for the front brakes end up in a vertical position followed by the arms on the second cross shaft for the rear brakes also being in a vertical position at the beginning of engaging the brakes with either the foot pedal or hand brake lever.
Sheldon's photo is of the more complex six rod system.
Last edited by DavidG; 03-13-2022 at 04:26 AM. Reason: added comment on deuce lover's photo.
Old 03-13-2022, 04:22 AM   #5
Harold Degand
Thanks Deuce Lover.
On my car, I have only one rod for each wheel.
Hand brake lever is directly connected to the dualshaft.
Old 03-13-2022, 04:24 AM   #6
Harold Degand
Thanks David G !!
Old 03-13-2022, 05:24 AM   #7
deuce lover
Thanks Deuce Lover.
Sorry as I thought you had the 6 rod system which was in France and Germany.
Old 03-13-2022, 05:46 AM   #8
Harold Degand
Don’t be sorry. These cars are quite mysterious.
Last september, I looked at a 32 made in Belgium. On this one, 6 rods system.
Mine was build in France, 4 rods.
On another belgian car, only 4...
Old 03-13-2022, 06:57 AM   #9
DavidG
DavidG's Avatar
Harold,
You're welcome!
Old 03-13-2022, 02:22 PM   #10
Fredsr
These are from David Rehor's excellent reference book, "The 1932 Ford Book."
Fredsr is offline   Reply With Quote
Old 03-13-2022, 02:37 PM   #11
DavidG
DavidG's Avatar
The next page with the illustrations is helpful also.
Old 03-13-2022, 03:43 PM   #12
Harold Degand
I’ve check the rods.
Mine are about 1/4’’ longer than on the table.
When I fit the clevis on the cross shaft, you can see how longer are the rods.
Si I suppose, the initial position of the cross shaft isn’t right.
Also, one rod is 5/16 UNF tread, the other ones are bigger.
File Type: jpg 9DC45205-B834-4060-9183-77B5447525CE.jpg (40.6 KB, 8 views)
File Type: jpg 4922B45B-EE78-4FF7-B4C0-06AD67C5DA7E.jpg (50.8 KB, 10 views)
