Old 08-31-2021, 10:23 AM   #1
rivcokid
rivcokid's Avatar
Default Ignition wiring - 1935 Ford Fordor
Good morning. Does anyone have a wiring diagram for the ignition switch on the 35 Fordor? I was told that it "quit working" and the previous owner put in a jerry-rigged switch next to it and completely bypassed the stock switch. I'm pretty sure I'll need to get a new ignition cylinder. Thanks in advance.
rivcokid is offline   Reply With Quote
Old 08-31-2021, 11:01 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Ignition wiring - 1935 Ford Fordor
VanPelt's is the place for diagrams.
http://www.vanpeltsales.com/FH_web/F...wiring1935.jpg
The column switches can be repaired since parts are available. The steering lock secures both steering and the ignition flip switch. All this stuff can be repaired if needed.
Old 08-31-2021, 02:52 PM   #3
rivcokid
rivcokid's Avatar
Thanks rotorwrench. I've been looking at parts. Shouldn't be an issue.
Old 08-31-2021, 03:06 PM   #4
JSeery
JSeery's Avatar
This is 36, but very similar I believe.
Old 08-31-2021, 03:30 PM   #5
rivcokid
rivcokid's Avatar
Thanks JSeery - that's more of what I was looking for. Just something to show how the original wiring was.
