Old 07-30-2021, 09:20 PM   #1
ilangford
Unhappy Light switch bail won't stay on - ugh!
Installed new light switch from Synders. the light switch is longer than the 'original' but works. This was done while I was installing a new wiring harness. I have the same problem with the switch on the steering wheel being too tight to turn on the lights; but that is not the MAIN problem. The steel 'tabs' the bail hangs on are way too short - one slight bump in the road, and my bail goes flying! Attached is picture of bail.
MY QUESTION - How do I get the bail to stay locked on these short metal tabs?
I have zip-tied it together, but that looks ugly!
ilangford is offline   Reply With Quote
Old 07-30-2021, 09:52 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Light switch bail won't stay on - ugh!
I've made a lot of minor adjustments on my bail with a vise and a pair of pliers. You should be able to tighten the loops pretty easily. You can also increase or decrease the pressure the bail puts on the switch, which can improve the feel of the steering wheel lever a bit.
My steering wheel lever didn't get all the way better until I installed a restored original light switch.
Old 07-30-2021, 10:08 PM   #3
Bob C
Are you saying these tab are to short?
Old 07-31-2021, 08:02 AM   #4
Big hammer
X-2 on the adjusting, did that in the 70's, make sure the bail is between the two nubbes on the housing!
get a bigger hammer tap done
Old 07-31-2021, 08:26 AM   #5
ilangford
Yes, Exactly!!!
Old 07-31-2021, 08:34 AM   #6
ilangford
I think I got it; wrap the bail wire tight around the notches in the nubs... thanks Bob C !!!
Old 07-31-2021, 01:28 PM   #7
J Franklin
J Franklin's Avatar
Squeeze and fit, repeat!
