Old 07-20-2021, 09:51 AM   #1
rayro39
rayro39's Avatar
Default Replacement accelerator linkage for 1939 Ford
Does anyone make a reproduction gas pedal link? Or can these be modified/replaced so they stay in place. Mine keeps slipping off the knuckle.
Picture is for reference
thank you!
rayro39 is offline   Reply With Quote
Old 07-20-2021, 10:21 AM   #2
marko39
Default Re: Replacement accelerator linkage for 1939 Ford
Is that the part that connects to the pedal? If so it doesn't look right. Bob Drake lists the two pieces and probably other venders as well.
marko39 is offline   Reply With Quote
Old 07-20-2021, 12:52 PM   #3
supereal
supereal's Avatar
That part is called "gas pedal linkage rod". For your '39 the part number is 48-9727.
At C&G (800-266-0470) the price is $9.
supereal is offline   Reply With Quote
Old 07-20-2021, 02:33 PM   #4
rayro39
rayro39's Avatar
Thank you supereal
Old 07-20-2021, 05:06 PM   #5
Kube
Kube's Avatar
I've restored numerous 39 Fords both very early and very late production vehicles and have never witnessed a throttle linkage that appeared even remotely similar to that one.
Old 07-21-2021, 06:12 AM   #6
Terry,OH
Terry,OH's Avatar
48-9747 is 10.75" long, it is connected to the Carb and the firewall accelerator linkage. I don't think that is what you have circled in your photo.
What your showing is not 39 Ford passenger car linkage. If you see page 4-11 & 12 of the 39 restoration book you will see the proper linkage.Do you have a photo of your linkage installed.
Terry,OH is online now   Reply With Quote
Old 07-21-2021, 06:38 AM   #7
mercurycyclone
Attached is photos of firewall accelerator linkage off a 39 Ford.
File Type: jpg FA12ACF3-3AF0-4DBA-A91F-63CA75228A75.jpg (41.7 KB, 70 views)
File Type: jpg AB509A5D-0D34-435A-88EC-DCC9975D312F.jpg (31.8 KB, 64 views)
mercurycyclone is offline   Reply With Quote
Old 07-21-2021, 08:03 AM   #8
DavidG
DavidG's Avatar
Note the return spring in mercurycyclone's photos above. The absence of such a spring in the non-original linkage in the photo in #1 is a serious safety hazard which could lead to a stuck wide-open throttle.
Old 07-22-2021, 09:29 PM   #9
Tinker
Tinker's Avatar
DavidG nailed it.
Old 07-27-2021, 02:44 PM   #10
rayro39
rayro39's Avatar
I ordered this one from cgfordparts. It's too short. They insist it's for a 1939 Ford Sedan. They said that's all they have.
It barely reaches my floor board. Here's my old one with the one they sent.
Old 07-27-2021, 02:59 PM   #11
deuce lover
deuce lover's Avatar
What's wrong with your original ? I have one you can have and its 4 3/8 total length.Just reimburse me for the postage after you get it.Click on my user ID and send me a message if interested.
PS if you can tig weld just graft the pedal end of the old rod to the new after measuring correctly.
Old 07-27-2021, 03:10 PM   #12
rayro39
rayro39's Avatar
The spring is stuck open. Or missing. I tried crimping it a little to hold on to the knuckle, but it still doesn't hold. It's just worn out.
Thanks Duece
Old 07-27-2021, 03:39 PM   #13
deuce lover
Ah okay. Mine is good used.Have had it 20 yrs and couldn't use it as I had a 35 and 36 .Its yours if you want it.
Old 07-28-2021, 07:30 AM   #14
Terry,OH
Terry,OH's Avatar
Suggest you take Sheldon up on his generous offer. Ford obsoleted the original rod used in 39 and replaced it with the one used in 1941. The 41 has a different connection to the linkage end. It used a rubber insulator to isolate vibration and noise.
If you remove the metal button from your old rod and drill a hole in it. Then cut to the proper length a longer piece of linkage then insert the cut rod into the metal button and solder it in place you can make your own replacement rod.
Old 07-28-2021, 08:26 AM   #15
DavidG
DavidG's Avatar
You have been warned; your non-original jury rig accelerator cross shaft lacking a return spring is a serious safety issue that you should not ignore.
