09-29-2017, 05:25 PM | #1 |
6 volt or 12 volt
Ok, just got my "new to me" 30 coupe home and am starting to sort some things out on it. What are your opinions on doing a 6 to 12 volt conversion. This car had a non working alternator on it and I have some doubts about the health of the battery. I am anticipating having to replace both the battery and the alternator or generator whether I go 6V or 12V. I see Mac's sells a 6 to 12 volt conversion kit that includes a new 12 volt alternator, light bulbs, rectifier, new 12 volt coil, and a starter field coil. Has anyone used one of these kits from Mac'c? It appears to include everything needed to do a complete conversion. Also looks like nothing would be altered to the point of not being able to go back to 6V if you wanted to. Anyway just curious as what opinions I could get. Thanks
09-29-2017, 05:46 PM | #2 |
Re: 6 volt or 12 volt
6 Volt stock system is VERY sufficient! DON'T follow the "FADS"!-- BE your "OWN" Man!
Bill W.
09-29-2017, 06:06 PM | #3 |
I have had no problem with 6 v for almost 10 years. If your 6 v system is lacking then you have other issues you need to identify and fix. Stay with what FoMoCo produced.
09-29-2017, 06:28 PM | #4 |
You will discover that there are strong feelings on every side of every Model A related issue. Decide what your "concept" is for your car and do what it takes. In this case, if maximum authenticity lights your fire, stick with 6 volts--many people are happy with that. If the APPEARANCE of authenticity is good enough for you, then you nave more options, including 6V voltage regulators either built into the cutout can or hidden in the generator, or an alternator built into a generator case. If reliability, convenience for use with modern accessories, and peace of mind is a priority, then join the rest of the world that has switched to 12 V, negative ground: there were good reasons for going to 12V (by contrast, negative ground was apparently just a technical toss-up but done for uniformity's sake.) I've done the switch but not with a kit. The kit you describe sounds complete except for a load resistor to put in series with the horn. I don't know what the rectifier would be needed for.
Eventually, you'll have to confront similar issues, like detergent oil, thermostat, fuses, antifreeze, sealed water pump bearings, shortened Pitman arm, and on and on. Have fun! Steve |
09-29-2017, 06:52 PM | #5 |
You may want to do some research on Macs shipping charges, customer service,
and parts quality. There are plenty of good vendors. Bob Last edited by Bob C; 09-29-2017 at 08:59 PM. |
09-29-2017, 07:52 PM | #6 |
09-29-2017, 10:15 PM | #7 |
09-29-2017, 10:18 PM | #8 |
Standing Elk
I installed a 6 volt positive ground alternator and left the rest original. I looked at the kit and was surprised by the low cost $137.37 http://www.macsautoparts.com/ford_mo...rsion-kit.html If you price out the items in the kit the total cost if you bought each item individually is around $335.01, so you save $200.00 by purchasing the kit??????????????? read post #5, #6 and #7 Kit Includes: 1 Alternator (A10000A12) $192.99 1 Starter Field Coil (A11081) $40.99 1 Coil (B6A-12029-B) $30.49 1 Ballast Resistor (A12001) $7.49 1 Horn Resistor / Voltage Reducer (A13802R) $27.49 1 Ammeter (A10850/30) $10.49 2 Headlight Bulbs (B13007E) $4.98 6 Dome, Dash, Cowl & Tail Light Bulbs (V13465D) $5.70 2 Stop Light Bulbs (V13465B) $1.90 1 Electric Wiper Resistor (V12873) $12.49
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 09-29-2017 at 10:24 PM. |
09-30-2017, 06:39 AM | #9 |
My six volt system has served me well for the 24 years that I have owned my '30 town sedan and apparently well for the 87 years that the car has around. But, as all have said, it's your choice.
Also, beware of Mac's. Marty |
09-30-2017, 08:52 AM | #10 |
This topic comes up often with same answers. Do what you like. Why did cars universally go to 12 Volt you ask? Answer: Smaller wire gauge for battery cables. Less amp draw for starter etc. Me personally I tour and have halogen headlights which are as bright as modern cars. I like the idea I can get a battery anywhere. (six volt not always that easy in a pinch) Can jump car with a modern 12 volt car. I can use 12 volt acc. if I whish. You reasons my differ or not matter at all. Fine Point show cars do not qualify for change. LOL
09-30-2017, 11:20 AM | #11 |
If you are going to run higher compression, and maybe other mods, go with the 12v system, for easier and quicker starting. Otherwise 6v is OK but do not use a stock generator if headlights or other mods have been made, it will not keep up and will throw solder if you try. I have used 12v since 1959 with no trouble. I also use the stock starter.
09-30-2017, 11:55 AM | #12 |
I have been running 12V systems in both of my Model A's without any changes to their starter motors. If you opt for a 12V system, omit the starter changes.
Bob Bidonde |
09-30-2017, 12:22 PM | #13 |
What are you going to do with the car ?
A conversion 'kit' is not needed. Anything needed is readily available, and, thats not much. A generator and starter will work fine on 12V. [ To me, an alternator just isn't right] That said, I find nothing wrong with 6 v. I just use a voltage regulator. |
09-30-2017, 12:59 PM | #14 |
You don't need a "new" ammeter, they are junk (at least al of the ones I have seen). Run a jumper wire across the two terminals at the back of the ammeter so some of the current goes through the jumper and some through the ammeter. You may be able to accomplish this at the junction box on the firewall depending on your wiring. You may want to run a wire in parallel to the one from the cutout and hook it to the other side of the ammeter. Use the same gauge wire as the present wire from the cutout to the ammeter. I have done this on my '32 but there is room behind the dash to work with. Remember that the gauge will read low.
Charlie Stephens Last edited by Charlie Stephens; 09-30-2017 at 01:15 PM. |
09-30-2017, 01:51 PM | #15 |
Leave it alone and use the money you save on gas and drive it.
09-30-2017, 04:31 PM | #16 |
If you have a generator, you can hand crank it or push start when the battery is low. You cannot do this with an alternator. BTW if you want can use a stock generator and run a 12V negative ground system. Just change the bulbs, polarity of the coil, a 12V coil or a ballast resistor, repolarize the generator, swap the wires on the amp meter and a 12V battery. You can probably get a 12V regulator from Fun Projects or Tom Wesenberg that will go in your generator.
09-30-2017, 04:48 PM | #17 |
Many different opinions will be given. Your the only one that will know what's right.
For 60 years, all of our Model A's have remained 6 volt. Never had a problem or reason to change. Also we haven't added after market electronics. All kept as from the factory. No jewelry. Enjoy. Last edited by WHN; 09-30-2017 at 07:54 PM. |
09-30-2017, 05:32 PM | #18 |
[QUOTE=Standing Elk;1533549What are your opinions on doing a 6 to 12 volt conversion. [/QUOTE]
I don't have an opinion but am curious, what do you expect to gain by converting to 12V?. |
09-30-2017, 06:27 PM | #19 |
09-30-2017, 06:47 PM | #20 |
If 12 volt, some say to add the modern bendix on the starter. I had a 6v cutout short somehow and caused engine elec. fire; went to the 1 wire 6 volt alternator after that incident on all 6 volt cars. An Optima battery is a good choice if running 6 volts.
