Old 04-12-2020, 08:40 PM   #1
New2modelA
Default How to remove the U-Joint from my Trans?
Hello All!
I need help in figuring out how to remove the U-Joint from the back of a 1947? side shift 3-speed?
If you could direct me to a u-tube or a simple tutorial would be fine too!
Thank you in advance!
Chris Kennedy
New2modelA is offline   Reply With Quote
Old 04-12-2020, 08:55 PM   #2
svm99
Default Re: How to remove the U-Joint from my Trans?
Use a 9/16 socket on an extension thru the splines, work your socket around until it fits on a bolt head, turn CCW until you remove the bolt, then slide the ujoint from the trans shaft. Put your trans in low or reverse to help prevent it from turning. Good luck!
svm99 is offline   Reply With Quote
Old 04-12-2020, 09:16 PM   #3
cas3
i've always been able to get on it with a box end wrench
cas3 is online now   Reply With Quote
Old 04-12-2020, 09:34 PM   #4
VeryTangled
VeryTangled's Avatar
I've always gone in through where the arrow indicates.
-Jeff H
Old 04-12-2020, 10:17 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by New2modelA View Post
Hello All!
Chris Kennedy
Hey Chris....Follow the advice in post #2 just below your post. Here is a picture of the bolt head that you are aiming for INSIDE the U-Joint. Easy Peasy! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-13-2020, 05:37 AM   #6
Kerk
Hint --- Save the Special washer- Thick and Dish shaped.. J. A. S.
Kerk is offline   Reply With Quote
Old 04-13-2020, 08:24 AM   #7
Hoop
Hoop's Avatar
Are you guys sure he's pulled the torque tube/rearend back?
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 04-13-2020, 08:54 AM   #8
Jack E/NJ
Jack E/NJ's Avatar
That was my thought too. Jack E/NJ
Old 04-13-2020, 12:58 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
You know, you've brought up a legitimate point, and one that remains a pet peeve of mine especially here on The 'Barn.....people asking questions or looking for guidance that aren't savvy-enough to include even the minimum amount of basic background information for a responder to be able to get a reasonably-complete picture of the problem situation. Heck, some of the "sharper" ones can't even remember to include the year and type of vehicle in question. I know that I have a difficult time trying to help determine what type of widget might work for a guy if he doesn't let us know which sort of vehicle he's trying to glue it onto. At the least, let us know your thoughts on what you may, or may not have accomplished so far relating to the question at hand. For instance, "I've removed my '47 Ford torque tube, but I can't figure how to remove the U-Joint." That's almost as bad as the ones that start a thread asking the type of question that results in a myriad of subjective answers, at best. Goober doesn't get an answer that suits his fancy and starts another repetitive thread a couple of months down the line wishin' & hopin' for an answer more in agreement with his desires. Common sense and situational awareness must come into play at some point. Ya can't just "wish" answers to be what you're hoping for. I'm done! DD
T5 W/TORQUE TUBE
Old 04-13-2020, 02:00 PM   #10
Hoop
Hoop's Avatar
Sometimes a little extra information sure helps clarify a situation.
Old 04-13-2020, 02:22 PM   #11
nelsb01
nelsb01's Avatar
V8COOPMAN;
To add to your great explaination, how and why don't people search Google before they ask questions? Everyone is asking for the easy answer.
Or better yet, why not search for manuals or service books before asking -- What do you use?
I wonder if there is a Forum for how to tie your shoes? Oops, forgot, I could have Googled that before asking that question.
nelsb01 is offline   Reply With Quote
Old 04-13-2020, 02:26 PM   #12
tubman
tubman's Avatar
What kind of oil should I use in my flathead?
No description; New? Old? Rebuilt? Stock? Street use? Racing?
I think it may be new guys trying to ask an innocuous question in an attempt to fit in.
Old 04-13-2020, 02:35 PM   #13
KGS
KGS's Avatar
Originally Posted by nelsb01 View Post
V8COOPMAN;
The problem with that falls into the category of "you don't know what you don't know" If someone has a question, gets the answer from Google, and never asks the question here, then many of us are "deprived" of some information that they would like or need or would never think to ask. I've certainly learned many things that I wouldn't even think to ask. A lot of things I've read about here I'll probably never use, but it makes for great reading.
Ken
KGS is offline   Reply With Quote
Old 04-13-2020, 02:35 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
I know that in spite of being a pretty fair speller, my dumb pride still makes me check with Wiki a LOT to keep from screwin' the pooch more often. Hell, I even find myself making prolific use of the 'Barn's own "search" function pretty regularly.....imagine that, huh? DD
T5 W/TORQUE TUBE
Old 04-13-2020, 02:39 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Ken
Ya know, that Ken dude kind'a has a pretty decent outlook about STUFF! Having a clue as to what might be interesting....and what's not, is key! DD
T5 W/TORQUE TUBE
Old 04-13-2020, 02:46 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
Man, if ever there was a perfect example....! DD
T5 W/TORQUE TUBE
Old 04-14-2020, 02:07 PM   #17
Hal Beatty
Hal Beatty's Avatar
V8COOPMAN;
What he said!
Hal Beatty is offline   Reply With Quote
Old 04-14-2020, 04:51 PM   #18
Hoop
Hoop's Avatar
"To add to your great explaination, how and why don't people search Google before they ask questions? Everyone is asking for the easy answer.
Or better yet, why not search for manuals or service books before asking -- What do you use?"
Exactly what do you think Ford Barn is?
Better yet, what do you think Google is?
You obviously got some confusion going on there.
Ford Barn is here as a resource ... even for the dumbest among us. Ask here first. I can refer you to some "first class" early Ford V8 information on Google that is completely wrong.
Stop telling guys not to post here because this is their first stop for shopping. You have no idea of the disservice you are doing to this site.
(By the way, those of you complaining about lack of information offered by a poster, ask questions.)
Old 04-14-2020, 05:02 PM   #19
expavr
expavr's Avatar
Well said. I agree.
expavr is offline   Reply With Quote
Old 04-14-2020, 05:39 PM   #20
WBrown
WBrown's Avatar
Same here. If everyone could google the answer, what use is a forum?
Aim low--achieve your goals.
WBrown is offline   Reply With Quote
