Old 05-02-2021, 01:02 PM   #1
31modelaguy
Default Fuel shut off valve question
I have a 31 model a and I’m not getting fuel out of the valve. At first just a few dribbles and now I can keep the valve open and nothing comes out. I’m sure it’s rust clogged. Can I remove the valve without taking the fuel tank out? Or does the tank need to be removed? It’s been running good just went to start it the other day and now this issue. Thanks for the help.
31modelaguy is offline   Reply With Quote
Old 05-02-2021, 01:19 PM   #2
Ernie Vitucci
Ernie Vitucci's Avatar
Default Re: Fuel shut off valve question
Good Morning...You can remove and replace the valve with the tank in the car. If you are then going to flush the tank...good idea to remove the floor boards and do the work outside. Ernie in Arizona
Ernie Vitucci is online now   Reply With Quote
Old 05-02-2021, 01:22 PM   #3
31modelaguy
Awesome thank you. It seems to just screw out so shouldn’t be an issue. Glad to see another fellow from Arizona here!
Old 05-02-2021, 01:29 PM   #4
Brentwood Bob
Have you put a little air back thru the outlet to loosen the plug up?
Brentwood Bob is online now   Reply With Quote
Old 05-02-2021, 01:43 PM   #5
Lefthander1930
Lefthander1930's Avatar
Talking Re: Fuel shut off valve question
Good idea to blow air back into tank & drain the tank, you don't need gas all over the place.
Lefthander1930 is offline   Reply With Quote
Old 05-02-2021, 02:40 PM   #6
Mulletwagon
Mulletwagon's Avatar
You should have a pencil filter inserted into the valve. Good idea to change it while the valve is out. Be sure to use thread sealer when re-inserting the valve.
Mulletwagon is offline   Reply With Quote
Old 05-02-2021, 07:50 PM   #7
700rpm
700rpm's Avatar
Disconnect your battery any time there is the chance of exposing raw fuel.
Ray Horton, Portland, OR
Old 05-02-2021, 09:05 PM   #8
mass A man
mass A man's Avatar
All the replies are very good ones. First, use a flashlight in the tank to see if the valve opening has something covering it. A friend with a '30 roadster had an annoying intermittent fuel supply starvation problem, he found a little silver foil cap liner from an old bottle of "something", sometimes covering up the hole to the valve! He got it out and that was the end of his fuel problem. One of the best things to come along for our "A's" is the cigarette filter for that valve.
mass A man is offline   Reply With Quote
Old 05-03-2021, 06:41 AM   #9
Redbird
Redbird's Avatar
No smoking during this procedure. Siphon all the gas out from the top first. Then get a big bucket under the valve. Remove the fuel line from the valve. Slowly remove the valve a little at a time and drain the gas that is left in the tank. It is best to have the car facing out of the garage. You don't want raw gas all over your floor. The pencil filter should come out with the valve.
Redbird is offline   Reply With Quote
Old 05-03-2021, 06:44 AM   #10
ericr
ericr's Avatar
what specific type of thread sealer do you use?
ericr is offline   Reply With Quote
Old 05-03-2021, 06:59 AM   #11
Mulletwagon
Back in the day we used teflon tape. It was even recommended by Holley for carb connections. Teflon tape is now considered to be gas soluble and is no longer recommended - but still used by some with no negative effect. The better solution now is to use liquid sealers, most notably from Permatex.
https://www.permatex.com/products/th.../?locale=en_us
Old 05-03-2021, 07:12 PM   #12
Joop
Joop's Avatar
31modelaguy
Doe you have the shutoff in the car or under the hood?
Where are you located in AZ..
Joop from Glendale, AZ
Joop is offline   Reply With Quote
Old 05-03-2021, 07:30 PM   #13
McMimmcs
McMimmcs's Avatar
Very wise and prudent suggestion! Wayne
Old 05-04-2021, 03:35 AM   #14
J.Ukrop
Yes, it's definitely possible to remove the petcock with the tank on. When you have the issue sorted, make sure to install a filter screen on the top of the petcock prior to filling it back up. These are cheap and also very functional.
J.Ukrop is offline   Reply With Quote
Old 05-04-2021, 07:41 AM   #15
Joop
Joop's Avatar
31modelaguy
