Old 12-20-2020, 01:00 PM   #1
Ruth
Default Hot Ammeter!
Oooo, baby. That ammeter got HOT!!
Ruth
Old 12-20-2020, 01:55 PM   #2
jm29henry
jm29henry's Avatar
Default Re: Hot Ammeter!
Lose wiring, can burn up the whole car!!
jm29henry is offline   Reply With Quote
Old 12-20-2020, 02:38 PM   #3
Ruth
Not mine!! Saw it for sale on e-Bay. https://www.ebay.com/itm/Ford-Model-...e/184587393089
Ruth
Old 12-20-2020, 03:47 PM   #4
redmodelt
redmodelt's Avatar
On a Model T, was wondering why it was back lit seeing the glow from the front. Was a nice meter before that!
Old 12-20-2020, 04:06 PM   #5
nkaminar
nkaminar's Avatar
Contacts should be bright shinny metal. Use some electrical grease. Make sure the fasteners are tight. Unless you are running 100 amps through your ammeter that should keep it from burning up.
Old 12-20-2020, 05:08 PM   #6
old31
That guy is wasting his time. Just take that hot ammeter and toss it in a bucket of cold water.
old31 is offline   Reply With Quote
Old 12-20-2020, 05:26 PM   #7
Ruth
Or the trash can?? Even melted the plastic off of the wire nuts!
Ruth
Old 12-20-2020, 05:31 PM   #8
wensum
wensum's Avatar
I've had all sorts of issues trying to get my speedster running properly and when local expert Errol, suggested looking at the ammeter, I found a similar result to that in the photo. With no fuse in the original wiring loom it can be the ammeter that fails when overloaded. Mine was a repo as I needed a 30 volt reading with an alternator, and it looks like the quality may not be up to the originals?
Somehow the points in my Mallory distributor fried themselves taking out the coil too. I can't comprehend how that happened, must have been a short, but replacing both (and the ammeter) has restored the motor to robust health.
wensum is offline   Reply With Quote
Old 12-21-2020, 11:13 AM   #9
katy
katy's Avatar
Were you running a 6 volt coil on 12 volts?
Old 12-21-2020, 05:42 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
I cured the hot ammeter with new nuts and soldering the bolt heads to the internal metal--- then I had to take it apart again to paint the cleaned brass and solder flat black because I could see it
Kurt in NJ is online now   Reply With Quote
Old 12-21-2020, 06:23 PM   #11
jimvette59
jimvette59's Avatar
Resistance causes heat !
jimvette59 is offline   Reply With Quote
Old 03-18-2021, 11:13 PM   #12
GT1929
Original ammeter cant figure out how to put it together mainly the needle it all came apart when glass broke pushing it in to small a hole in repo. dash.
GT1929 is offline   Reply With Quote
Old 03-19-2021, 04:57 PM   #13
john in illinois
john in illinois's Avatar
I am thinking of switching to a voltmeter due to the risk of fire with the ammeter.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 03-20-2021, 10:31 AM   #14
katy
katy's Avatar
Originally Posted by john in illinois View Post
I am thinking of switching to a voltmeter due to the risk of fire with the ammeter. John
Now you've done it, I've been driving for 65 years and never realized that ammeters are a fire hazard.
Old 03-20-2021, 11:22 AM   #15
Y-Blockhead
Y-Blockhead's Avatar
John
John, let us know when you find a good voltmeter that will fit in the stock dash opening. I'm sure more than one person feels the same as you.
Old 03-20-2021, 11:53 AM   #16
DHZIEMAN
Dump the ammeter! Before doing so Check each terminal to the case of the ammeter! Also look for short or burn marks anywhere behind the suspect meter looking for a "not wanted ground point!" If either terminal was shorted to ground, by the backing area or the case of the meter that is the problem. If not, replace the ammeter and install loose (INSULATE THE TERMINALS) and check if it operates properly. If so, the shorted ammeter was the problem. Ground can be a good thing, and in the wrong place a bad thing!
DHZIEMAN is offline   Reply With Quote
Old 03-21-2021, 03:38 PM   #17
Patrick L.
Patrick L.'s Avatar
