Old 01-02-2021, 05:59 PM   #1
hombres ruin
hombres ruin's Avatar
Default Whirring noise .. from I don’t know where
Hi. My 41 coupe is making a whirring noise and I need help to pin it down. So 6V new generator (replaced the older one about 3 months ago) water pumps are sealed bearing units from van pelt. A new belt went on when the pumps went in about a year or so ago. The belt is at the correct tightness per the 41 handbook . 1 inch deflection midway between generator and water pump pulley. So on start up it idles perfect no noise . When she warms up and I have driven the car for some time . When i idle the car in park and give it some gas to a higher RPM she makes the noise . Most times it lasts about 10 seconds and it’s gone and back to a noiseless idle. Other times it’s sustained until I turn the engine off and start her up again and it’s gone. I put belt dressing on the fan belt and the noise still occurs. It will make a whirring sound then it sounds like the belt gains traction and it stops and idles with no noise . Any ideas ? Time for a new belt?
"I have built my organisation on fear"..Al Capone.
hombres ruin is offline   Reply With Quote
Old 01-02-2021, 07:28 PM   #2
Mart
Mart's Avatar
Default Re: Whirring noise .. from I don’t know where
Start off with a sanity check. Does it make the same noise when the belt is removed? At least that would prove the noise is belt related (or not). Mart.
Old 01-02-2021, 08:31 PM   #3
hombres ruin
I will run it tomorrow then take the belt off and see what it does . I have a video of it but I can’t upload for some reason
Old 01-02-2021, 08:40 PM   #4
drolston
drolston's Avatar
Long shot. Be sure you have enough free play in your clutch, and that the return spring on the throw out bearing is working. The test is to put your foot on the clutch when the noise is happening. If the throw out bearing is singing, that will change the noise; probably make it go away.
Old 01-02-2021, 10:27 PM   #5
Ford Freak
I struggled w/that annoying problem for a few yrs . I would spray some belt dressing spray on the belt & it would temporarily go away . Tried different belt tensions . Finally I bought a new belt from NAPA . Problem gone . Just wish I had tried that sooner ! - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 01-02-2021, 11:43 PM   #6
aussie merc
aussie merc's Avatar
i get the same noise at times have found that holding some hard bar soap on the sides of the belt while running cures the noise until the next bout of wet weather
aussie merc is offline   Reply With Quote
Old 01-03-2021, 06:02 AM   #7
PeteVS
PeteVS's Avatar
When it's making the noise, hold a broom handle up against your ear and then press end of the handle up against the generator or whatever else. It will act like a doctors stethoscope and you'll know what's making the noise.
Old 01-03-2021, 07:24 AM   #8
chap52
chap52's Avatar
The ol' broom stick ...can you still find a wooden one?
Just remember what mom said..."Don't put anything smaller than your elbow in your ear." Chap
Old 01-03-2021, 08:46 AM   #9
corvette8n
corvette8n's Avatar
Or get one of these, I’ve had one for years, got mine from a swap meet tool vendor.
File Type: jpg 28FF3835-410D-44A1-8D2E-7B79B415FDA7.jpg (46.8 KB, 42 views)
Old 01-03-2021, 11:04 AM   #10
hombres ruin
I am in medicine so I grabbed my stethoscope and listened to the generator while the noise was happening and it wasn’t present there. It was normal.
Old 01-03-2021, 05:25 PM   #11
john in illinois
john in illinois's Avatar
Long shot,I once had a starter bendix contact the ring gear intermitantly
New bendix fixed it. It made clics and whirrs. Took a while to find it.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 01-04-2021, 02:59 PM   #12
Graeme / New Zealand
Graeme / New Zealand's Avatar
Holy moly.... imagine the Doc using this on you it would give you a "heart issue" rather than diagnose one.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-04-2021, 04:05 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
Whirring noise?
Next time you hear it, look UP , it might be one of these.
Old 02-23-2021, 12:40 PM   #14
hombres ruin
So I ran the motor minus the belt, the gen and new water pumps weren’t in play. On higher RPMs the noise was there lasted for 10 seconds then went away. Gassed it again noise came back for seconds then gone. I seemed to have isolated to the bottom fan pulley. It’s not touching anything . The noise sounds like a low whooshing . I have no oil pressure issues no fuel issues no over heating issues . It doesn’t happen at idle only on higher RPMS and even then I won’t do it.. I got a new gen, new Napa belt and it’s still there . Any ideas? Bearing?
Old 02-23-2021, 03:59 PM   #15
jimvette59
jimvette59's Avatar
Vacuum leak or exhaust leak
jimvette59 is offline   Reply With Quote
Old 02-23-2021, 06:40 PM   #16
Talkwrench
Talkwrench's Avatar
You have an Aluminum timing gear ?
Old 02-23-2021, 06:59 PM   #17
VeryTangled
VeryTangled's Avatar
hi hombres ruin, yeah it would be super helpful to see/hear a vid. But FordBarn donesn't allow videos to be posted/uploaded.
You'll have to put it up on another host, then link it here. YouTube allows you to make an account that'll let you send the video there.
-Jeff H
Old 02-24-2021, 11:17 AM   #18
pistonbroke
I would check fan blades for cracks, fan hub bolts and my crankshaft pulley bolt for tightness. had a similar noise on my stove bolt six just before the the fan blade came threw the hood. good luck, Tim
Old 02-24-2021, 11:22 AM   #19
pistonbroke
I assume you have the same lower pulley and fan as mi 41 pickup.
Old 02-24-2021, 11:45 AM   #20
hombres ruin
Thanks .. I will check for a vacuum leak tomorrow..
