Old 03-16-2023, 05:32 AM   #1
Lenny Bruce
Default Oil pump
Hello all! I would like to remove my oil pan on our ‘30 Tudor clean it out really good seeing we don’t know when and if it has ever been done. My confusion is Les Andrews Red book says place the oil pump back into the block a small Jack placed between the frame and the block with a 1/4 inch rod inserted to the side plug hole will aid in holding it in place. My question is how is the Jack and the 1/4 inch rod not in my way when reinstalled the oil pan? I guess I can’t picture it in my mind. Would anyone have any pictures by chance? Thanks fellas…..
Lenny Bruce is offline   Reply With Quote
Old 03-16-2023, 06:11 AM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Oil pump
Get one of these little fellows. Insert it into the side of the block, where there is now a small pipe plug, and run the screw in to hold the oil pump in while you remove the pan. You also use it to install the oil pan. Once the pan is in, remove this little holder and reinstall the plug.
https://www.brattons.com/OIL-PUMP-HO...ductinfo/9895/
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 03-16-2023, 06:25 AM   #3
Lenny Bruce
Ahhhh thanks Jim that will make life MUCH EASIER!!!!
Really appreciate it!!!
Old 03-16-2023, 11:32 AM   #4
J Franklin
J Franklin's Avatar
A slip of paper between the side of the pump and the block as a wedge is what I use to hold the pump in place.
Old 03-16-2023, 01:56 PM   #5
81ls1camaro
Its just a little pipe plug drilled and taped for a small screw if you want to make one. I did buy one made myself, but would easily be made at home.
81ls1camaro is offline   Reply With Quote
Old 03-17-2023, 10:07 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
This story is of a tragedy with an oil pump installation. Many moons ago, I had a Model "A" engine rebuilt by an experienced shop. It was a year or two later when I put the car on the road, and the engine ran fine around town. Then I drove the car on the highway, and after a mile or two, the engine started to clatter and knock. When I drove it slow, it was quiet running. Later on I dropped the oil pan, and to my horror, I found the oil pump was tied into position with clothesline. The clothesline disintegrated and clogged the oil pump screen. By the time I found the problem, the shop was out of business.
Bob Bidonde
Old 03-17-2023, 10:55 AM   #7
Flathead
Flathead's Avatar
Jeez, wonder why they went out of business??
Flathead is offline   Reply With Quote
Old 03-18-2023, 02:55 PM   #8
Terry, NJ
Terry, NJ's Avatar
Lenny, Don't forget to open the port at the top of the pump (where the oil flows out to the engine from) to 7/32 (.218) if it is not out to this size already. Early ones seem to be a little smaller, later ones are a little larger. Make sure that it is thoroughly clean of all chips afterwards. Good Luck !
Terry
Old 03-18-2023, 05:17 PM   #9
Lenny Bruce
Great to know thank you Terry!!
Old 03-19-2023, 03:23 PM   #10
mshmodela
mshmodela's Avatar
My block has no such hole.. any suggestions?
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-20-2023, 10:10 AM   #11
J Franklin
J Franklin's Avatar
Reference was a hole in the pump body.
Old 03-20-2023, 01:01 PM   #12
ModelAMitch
ModelAMitch's Avatar
You could get a small bolt with the same thread size (bring the plug with you to the hardware store) and use it to temporarily hold the pump in place.
ModelAMitch is offline   Reply With Quote
Old 03-23-2023, 10:42 AM   #13
katy
katy's Avatar
The plug thread size is 1/8"NPT, bolts don't come w/that size thread.
Old 03-23-2023, 11:06 AM   #14
JayJay
Be careful. The hole in the side of the block is 1/8"NPT, which is a 27 TPI. A 1/4-28 TPI might seem to fit but the thread pitch is slightly different and you will bugger up the block. Either buy one of the aftermarket gizmos referenced above (I did) or make your own by drilling and tapping a 1/8" NPT pipe plug.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 03-23-2023, 03:38 PM   #15
J Franklin
J Franklin's Avatar
Buy the tool.
