Old 01-21-2021, 11:20 PM   #1
arkusvt
Default ultimate flathead
volume 50, #2 of "old cars" magazine, just out, contained an interesting article re: an engine put together many years ago and run in a '32 roadster. this was a 239, naturally aspirated with 3 97's and a few after market speed parts. dyno reading was 350 h.p. and rev'd regularly to 10,000 rpms, sometimes all the way to 12k. if you can acquire a copy of this issue, as i say, an interesting story and you can be the judge.
arkusvt is offline   Reply With Quote
Old 01-22-2021, 09:54 AM   #2
Jim in Wisconsin
Default Re: ultimate flathead
I read that article too, 10,000 on a flathead? Maybe that tach was reading wrong.
Jim in Wisconsin is offline   Reply With Quote
Old 01-22-2021, 01:08 PM   #3
McMimmcs
McMimmcs's Avatar
I totally agree with you??
Old 01-22-2021, 10:13 AM   #4
flatjack9
flatjack9's Avatar
Somebody had their foot on the dyno beam scale.
Old 01-22-2021, 10:13 AM   #5
Tim Ayers
Anyone selling popcorn? I'll looking forward to the responses about this one...
Tim Ayers is online now   Reply With Quote
Old 01-22-2021, 11:20 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Suspect the key words are in the first post, "this was a 239"
Old 01-22-2021, 11:41 AM   #7
tubman
tubman's Avatar
With that kind of numbers, whether it was or wasn't a 239 is irrelevant.
Old 01-22-2021, 03:30 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
"Was" as in used to be, but now in pieces
Old 01-22-2021, 12:32 PM   #9
Ross F-1
Ross F-1's Avatar
Here's the article: https://www.oldcarsweekly.com/featur...ong-haul-deuce
"....Now 10,000 rpm might sound like a lot of fun, but it did present some problems."
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 01-22-2021, 12:46 PM   #10
tubman
tubman's Avatar
Getting that kind of RPM's is easy; just use a tachometer for a 4 cylinder engine.
Old 01-22-2021, 12:52 PM   #11
Tim Ayers
Tub, I thought the same exact thing. Either wired wrong or it's a 4 cly. tach.
Old 01-22-2021, 04:43 PM   #12
Pete
Or with a cable drive tach, use a 1 to 2 drive unit.
Here is a pic of that setup with the tattletale at 9300. Really gets the fans talking after the race. This was a fairly stock 4 banger.
Old 01-22-2021, 12:51 PM   #13
Tim Ayers
During this time, I once drag raced down Yale Boulevard in Nampa (this was a bout 1963). I tried a full-throttle power shift at 10,000 rpm and the result was a blown clutch, transmission, drive shaft, differential and a broken axle. Witnesses said the front end came off the ground a good 2 feet.
This is part where I stopped reading. I hope this author got an A in their creative writing class. Give me a break...
Old 01-22-2021, 02:19 PM   #14
Ross F-1
Ross F-1's Avatar
Originally Posted by Tim Ayers View Post
[I]...
I liked this part:
The ’55 had an unbuilt 283-cid V-8 so I bought a motor adapter and installed the 283 in my ’32. What a disappointment that was. While I no longer had the heating problem, I had also lost a whole lot of power. It was OK, just not as thrilling as the full-race flathead.
Old Cars is usually a very interesting read, but this is ridiculous.
Old 01-22-2021, 02:40 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Give
Me
A
Friggen'
Break!
DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-22-2021, 01:30 PM   #16
deuce5wndw
deuce5wndw's Avatar
Maybe it's a case of the older I get the faster I was!
deuce5wndw is offline   Reply With Quote
Old 01-22-2021, 01:37 PM   #17
Tim Ayers
Anyone catch the part about how fast he went after installing the 4.33 rear? The "facts" of this story are approaching science fiction levels.
Should have taken this beast to Bonneville.
Old 01-22-2021, 02:35 PM   #18
KiWinUS
KiWinUS's Avatar
Fiction Novel.
Old 01-22-2021, 02:37 PM   #19
petehoovie
petehoovie's Avatar
Old 01-22-2021, 02:44 PM   #20
19Fordy
19Fordy's Avatar
Tim Ayers: Your comment was fantastic. Liked the 2 feet off the ground.
