Old 01-25-2021, 07:47 PM   #1
kwisor
kwisor's Avatar
Default how do you clear the vent hole in shifter tower
hello
i may have a clogged vent hole in the shift tower. how do you check it and clean it? do you have to pull the shifter to clean it?
thank you
kevin
kwisor is offline   Reply With Quote
Old 01-25-2021, 08:04 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: how do you clear the vent hole in shifter tower
Just stick a piece of wire thru it.
Old 01-25-2021, 08:09 PM   #3
Big hammer
Use a small drill bit and turn by hand
get a bigger hammer tap done
Old 01-25-2021, 08:15 PM   #4
kwisor
kwisor's Avatar
thanks
kevin
Old 01-26-2021, 10:40 AM   #5
McMimmcs
McMimmcs's Avatar
That certainly makes sense ! Thanks
Old 01-27-2021, 10:17 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
A torch tip cleaner works well .
Old 01-27-2021, 10:19 PM   #7
Rich in Tucson
Rich in Tucson's Avatar
If totally plugged a slowly hand turned drill bit and a source of vacuum to catch the debris.
Rich in Tucson is offline   Reply With Quote
