Old 01-18-2021, 12:45 AM   #1
7_Zero
7_Zero's Avatar
Default Running an internally cracked block on a Gordon Smith compressor?
Upon removing the head on my brothers car we found cracks on cylinders 2 and 3 going between the valves and the cylinder. He has plans to put a lot of miles on this car and decided on rebuilding an engine. The rebuilder said the cost to repair the cracks (if they are repairable) would add quite a bit to the cost so my brother has acquired another block to rebuild. However, the rebuilder said that if we send in the current engine, and it is repairable, or if they can use other parts from the engine, they might give him a credit towards his new engine.
On the other hand, I have always thought it would be cool to make a Gordon Smith compressor and wondered if this engine would work. The babbitt is in good condition with the exception of the rear main which is cracked, but has held up well for the last couple thousand miles. I wondered if the cracks in the block might not be as big of a problem on a compressor as cylinders 2 and 3 would be pushing air and not undergoing the combustion cycle. Is there any validity to my thinking? Would this be a worthwhile undertaking or should we send it off with the hopes that it can be saved?
Thanks!
7_Zero is offline   Reply With Quote
Old 01-18-2021, 11:23 AM   #2
katy
katy's Avatar
Default Re: Running an internally cracked block on a Gordon Smith compressor?
Valve seat inserts might cure the problem.
Old 01-18-2021, 11:45 AM   #3
Dave in MN
Dave in MN's Avatar
JMO: For the limited amount of time you would use the compressor, I think the block would work for the compressor. If you are doing a rebuild on another block, best use all new components in it. The items you could re-use would not cost that much to replace with new. I rebuild engines...so I have my opinions...
Building a Gordon Smith compressor is on my list of thing to do when I retire. Good luck on the project!
Good Day!
www.durableperformance.net
Dave in MN is offline   Reply With Quote
