Old 01-06-2021, 02:08 PM   #1
Don S
Default Lite rust inside block
I removed my top hose to get at the thermostat,because I was experiencing an over heat situation . I checked the thermostat on the stove in a large can of water. Used a laser reader to check when thermostat opened , 192 deg. Too high for a 160 degree thermostat,and for my general needs. I will replace the thermostat,but I noticed looking down the gooseneck that there is a light rusting that I would rather not have.My A is in winter storage . Is there a safe way of neutralizing the rust by filling up the block only ,letting it work for awhile then flushing, without having to start the engine ? What product is safe for this process ?
Thanks Don
Don S is offline   Reply With Quote
Old 01-07-2021, 03:29 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Lite rust inside block
Thermocure
Old 01-07-2021, 05:35 PM   #3
Don S
No luck here,auto supply stores don't know about this product .
Thanks for the suggestion
Old 01-07-2021, 06:42 PM   #4
Synchro909
Synchro909's Avatar
Go online and look at Liquid Intelligence. They do a range of products but you will likely only be interested in their 239 Engine Cooling System Cleaning Kit. They say it comes with a money back guarantee so they must be confident it is good.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-07-2021, 07:00 PM   #5
eagle
eagle's Avatar
Are you running anti freeze or straight water or ????.
Old 01-07-2021, 08:07 PM   #6
Don S
Running distilled water with rust inhibitor. Only use anti freeze for winter starage
Old 01-07-2021, 08:19 PM   #7
Don S
Synchro , I checked it out on-line, looks interesting, but need those if locally available.
Thanks for your input
Old 01-07-2021, 09:34 PM   #8
Chris Haynes
Chris Haynes's Avatar
I have successfully cleaned and de-rusted my entire cooling system with RUST911.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-08-2021, 12:14 AM   #9
CWPASADENA
CWPASADENA's Avatar
X2
Chris W.
CWPASADENA is offline   Reply With Quote
Old 01-08-2021, 06:15 AM   #10
updraught
updraught's Avatar
https://www.amazon.ca/Thermocure-Coo.../dp/B00R74I5UY
Free delivery.
updraught is offline   Reply With Quote
Old 01-08-2021, 06:05 PM   #11
Don S
I used a product called Kleen -Flo , mixed the container with water and filled the block. After about 1 hour I drained it and flushed with garden hose till clear. I repeated the process . Very little color in the second flushing . I will replace the anti-freeze until spring.
Thanks all for your suggestions
Old 01-08-2021, 09:42 PM   #12
eagle
eagle's Avatar
If there is just a bit of rust on the surface of the water jacket etc it isn't time for panic. Go to your local auto parts store, get a radiator flush kit and use it as directed. Then use a good quality anti-freeze with built in rust inhibitor. If the system is plugged up, that's a different story.
Old 01-09-2021, 08:22 AM   #13
1crosscut
1crosscut's Avatar
Your choice but now that you have the rust taken care of and refilled with a 50/50 mix of distilled water and antifreeze leave it in there.
Seems to me the rust inhibitor your using isn't up to snuff.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 01-09-2021, 01:49 PM   #14
Ernie Vitucci
Ernie Vitucci's Avatar
Agree with 1crosscut...I simply use 50/50 antifreeze and it stays green from year to year and the engine runs cool. I do run the Vintage Precision Thermostat housing and the thermostat that they provide...very good system...Ernie in Arizona
Old 01-09-2021, 02:05 PM   #15
Don S
Ernie,and crosscut , I ordered a Vintage Precision thermostat and housing last week, never really liked the one in the hose , also makes the hose more difficult to instal. Should be good to go this spring.
Thanks all
Old 01-09-2021, 03:56 PM   #16
whirnot
whirnot's Avatar
Fill the cooling system with vinegar, let it sit for two weeks, or three. Flush and immediately fill with 50/50.
Inexpensive and works.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
