Old 11-17-2020, 05:18 PM   #1
30-9
Default Tool question
Hi Gents
Will I ruin a 18 volt saws all if I mate it with a 20 volt battery?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 11-17-2020, 05:53 PM   #2
koates
Default Re: Tool question
It might help if you could explain exactly what you are trying to do. But the short answer is NO and it MIGHT be OK. Need to know make of saw and charger and specifications and also specs of battery. Regards, Kevin.
koates is offline   Reply With Quote
Old 11-17-2020, 05:58 PM   #3
KiWinUS
KiWinUS's Avatar
Desalt now has an adapter for 18 bolt tools that allows you to use a 20volt battery. So as for as their tools you should be good to go.
Old 11-17-2020, 06:35 PM   #4
WABOOM
WABOOM's Avatar
I believe all the big names that say "20 Volt" are actually 18v and they are advertised as "20 Volt Max"
WABOOM is offline   Reply With Quote
Old 11-17-2020, 08:26 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Probably similar to running a 6 volt starter or heater motor on 12 volts, just runs faster.
