I have four 5 bearing camshafts. one has the second and fourth bearing with oil grooves. the grooves are wider and deeper than three bearing camshafts. The 2nd and 5th bearings are the same size (1.558in) as the other 3 bearings.
The other three have no oil grooves on the 2nd and 5th bearings and they are smaller (1.44 inches dia) than the other 3 bearings. Any idea why they are smaller and what the difference between the cams mean. |
Ford made 3 different 5-brg. cams. First all 5 brgs. were finish-ground to the same size to match the blocks being used. 2nd series #2 & 4 were finish-ground to a smaller diameter to make installation quicker and easier, blocks were now 3 bearing. 3rd series were merely rough-machined because it was cheaper to do so. The lobes were all the same. Value? All the same.
Thanks Jim, I thought you would know the answer.
camshaft question.
my 28 tourer has a better performing engine that my 28 ute. the first was overhauled by an old-timer, the second by the same workshop but a new owner. I believe the first had a reground cam. I am advised a "B" cam will greatly outperform the original. I wonder if the A cam can be reground to "B" specs or reground to be more like the B. If so I'd get it done . there are plenty of you wise folk to give me an opinion which would be received with gratitude. thankyou. gary
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
When having a cam reground for ANY purpose, have them use a modern design profile that has clearance ramps and uses 1 inch diameter lifters.
#9 | |
![]() Quote:
I can put you onto a mob here in Melbourne who reground my cam shafts. Their grind goes on a standard camshaft which you would need to supply as a core. They are beyond a B grind for performance but in my opinion, to improve an engine we should look at all 3 of the "three Cs" at once and do a little to each. They are Carb, Cam and Compression. That is what I did to the car I use to tow the camper. The specs are: Inlet Opens at 21°, closes at 63?° (the data card is not clear) Duration 263° Exhaust Opens at 67°, closes at 16° Duration 263° Lift is 0.288"
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
thankyou to Jim Brierley and Synchro.
Valuable is the knowledge of Ol' timers. received with gratitude. gary
Use larger than 1" lifters. 1" may be OK on a stock cam but not for a performance cam. Most adjustables today are larger than some used several years ago.
#12 | |
![]() Quote:
The reason OEM cams require larger than 1 inch face lifters is they are of the 3 arc design and the lift curve has NO clearance ramps. The velocity is high at the nose also. This is why the nose wears off prematurely. |
#13 |
When getting into larger than stock cams, the larger face lifters will help.
Some we run are 1.2 dia and used on cams with bearings larger than 1.75 dia. Of course pushing the .500 lift or higher. John
As Carroll Smith wrote; All Failures are Human in Origin. |
#14 | |
![]() Quote:
If a given cam is designed to run on a 1 inch lifter, going to a 1.1 inch lifter is NOT going to change anything except add unecessaary weight to the valve train. Running a smaller diameter than specified lifter will quickly destroy the lifter and the lobe. |
