Old 02-14-2011, 09:21 PM   #1
delphia2
delphia2's Avatar
Default 1934 ford p/u original steering wheel
how do I remove the original steering wheel to restore it. all help would be much appreciated. restoring 1934 ford p/u
delphia2 is offline   Reply With Quote
Old 02-14-2011, 09:52 PM   #2
34pickup
34pickup's Avatar
Default Re: 1934 ford p/u original steering wheel
You have to have something to go behind the steering wheel to pull it because the wheel does not have any drilled and tapped holes to use a wheel puller.Or you could drill and tap some holes in it after you remove the horn button to use a puller.
Did you get the truck in your avatar from Ooltewah Tennessee?
34pickup is offline   Reply With Quote
Old 02-14-2011, 10:48 PM   #3
delphia2
delphia2's Avatar
Yes I did, last year I bought it from Kevin
