I am thinking of taking my 1930 stock Model A on a 1/8 drag strip.
Would using 1934, 17 inch wheels/tires work ok? |
This raises a whole bunch of questions.
Why run the stock car on the 1/8 drag strip? What do you mean by stock? What is the body style? Why do you want to use 17 inch wheels and tires? I am not the 17-inch expert, but I think the 17-inch wheels fit the Model A without modifications. Using the 17-inch wheels and tires would probably not give you any advantage and would make the car non-stock. The 19-inch tires may be an advantage as there would be less tire patch area and therefor less friction than the 17-inch tires. I don't think you have to worry about hooking up to the road surface with a stock Model A.
It is possible to spin the tire on the rim, and tear the valve stem out
Why run the stock car on the 1/8 drag strip? --Its called Vintage racing. A bunch of people having fun at a drag strip racing each other. The cars are older than 1954 but mostly model As. Its fun! What do you mean by stock? --Completely stock 4 cylinder engine What is the body style? --Coupe. Why do you want to use 17 inch wheels and tires? --Because I have a set of 1934 wheels with new tires. --The car has been off the road since 1972. The tires are old but hold air. |
Let us know what your fire breather turns...
The rolling diameter of all Ford wheels from 1930 thru 1948 are within 1/2" of each other.
Bob Bidonde |
The YouTube guys seem to film the V8s but there were plenty of flat 4 and OHV Model As running at the recent Antique Nationals - https://www.foureverfour.com/history/
https://www.youtube.com/watch?v=SAUyBDEq2ZQ&t=214s https://youtu.be/67Abq2mO8tY?t=1051 https://www.youtube.com/watch?v=sDebn1amuz0 https://www.youtube.com/watch?v=dWopU1P8KVw |
This is the time to beat- https://www.youtube.com/watch?v=pefSVuL3WpQ
2024-2025 MAFCA Technical Director |
#10 | |
![]() Quote:
The crime of exhibition of speed in California prohibits a person from accelerating or driving at a rate of speed in a manner that is dangerous and unsafe in order to show off or make an impression on someone else. |
