These front 40 brakes are squeaky and practically new. Is there a trick I don't know about to eliminate the dang squeak?
Thank you, Guy |
I would switch to Bendix brakes up front. MUCH better.
If they squeak when you apply the brakes, your brake shoes may be glazed smooth.
Remove the drums and sand each shoe surface with 60 grit sandpaper to make them rough. Wear a mask and don't air bow the dust away. Also use sand paper to rough up the inside dia. of the contact surface of each drum. Then go for a ride. OEM shoes were made of softer material and were riveted on. Bonded shoes use harder materials. Last edited by 19Fordy; 06-13-2020 at 11:45 AM. |
#4 | |
![]() Quote:
Did you arc the shoes to fit the TURNED drums? If you simply replaced the shoes and put the used drums back on, you are likely going to live with the squeak...
Thank you, good advice I'll go work on them.
