I'll admit, it's been nearly 50 years since either my friend Dave or I have removed a body for any reason, and 50 years ago the body mount bolts were 50 years newer in the A's we were working on. Body mount bolts being cheap, I'm not complaining about cost, just wondering if its even worth the effort? The body is very nice and not a representation of the hardware, as I have had to cut the rear fender bolts, the splash apron & running board bolts, so I doubt the body bolts would be any different. Cut them with a torch, break them off with a really big breaker bar or even an impact wrench? I am open to suggestions, and probably will not have the opportunity to attempt it for a few days because of more rain on the way.
Thanks in advance! ![]() |
I have been able to break most of the body bolts off using vice grips on one side and a good fitting wrench on the other side. I have also used a cold chisel to split the nuts. So far I have not used a torch on the bolts because of possible collateral damage to the model A. Do what works best for you.
An angle grinder works well to cut them off.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
IMO..if the cost of the project is not an issue, cut them off.!.if you're blessed with patience, and a real good friend to hold a wrench, band-aids for skinned knuckles, lots of PB Blaster, well, you get the idea.!
I picked the hottest, most humid summer day, and had my wife help me..!! Ended up getting the bolt kit anyway,.!! Kb |
Steve great to see your working on the car and is this the model A or the 1934? I use one of them Milwaukee impact wrench and let the bolt determine its fate. If she is stuck it will break .. The 34 has some bolts that are harder to get to and as said vice grips on the other side will help if you dont have a helper. Hope all is good buddy and haven’t seen you in awhile...
Wanted Ford oiler oil cans Thanks |
Sometimes a nut splitter will work.
If you heat them cherry red, the nuts will always come off.
Dean and Steve are spot on about heat
Tighten them until they break. Using Kroil will loosen most of them. Apply it and let it sit overnight. http://www.kanolabs.com/msn/?msclkid...f711366d8ce064
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
