Old 04-10-2020, 05:10 PM   #1
dlfrisch
dlfrisch's Avatar
Default Help - ‘28 Sport Coupe Windshield
How do I disassemble and install new windshield glass ? The frame is removed from the vehicle and is on my work bench. It is real solid - I can’t move (separate) any of the frame, sides top or bottom. There is two small #6 x 32 short screws - removed on each side. Nothing else holding except the gasket...???? Ideas - guidance
Dave
dlfrisch is offline   Reply With Quote
Old 04-10-2020, 05:17 PM   #2
daren007
Default Re: Help - ‘28 Sport Coupe Windshield
Look for two more screws. Use a block of wood and hammer and have at it.
daren007 is offline   Reply With Quote
Old 04-10-2020, 06:07 PM   #3
SteveB31
SteveB31's Avatar
A total of sixe screws (3 per side) at the top must be removed, then carefully use a 2x4 and hammer to remove the top part of the frame
SteveB31 is offline   Reply With Quote
Old 04-10-2020, 07:45 PM   #4
dlfrisch
dlfrisch's Avatar
Yes - I had to drill the two screws (one each side) trim the edges with a small chisel and hammer away. I did get top piece off. I’ll work on the rest tomorrow. Continue disassembling and figure the gasket situation and reassembling.
Old 04-10-2020, 09:44 PM   #5
daren007
You can use glass setting tape if you can find it. Go to a glass shop and ask for the black sticky stuff used in windshields and back glass. I forgot what they call it but they will have partial rolls laying around. Do some dry runs to figure out how to keep the glass centered. When done you will have a better job without leaks.
Old 04-11-2020, 03:37 PM   #6
rocket1
I used the caulking a Marine supply sells for boat windshields,you fill in the channel and tap the glass in then wipe off excess,works great.
rocket1 is offline   Reply With Quote
Old 04-12-2020, 09:13 AM   #7
rotorwrench
rotorwrench's Avatar
As long as the caulking doesn't have a bad reaction with the steel, it will work. A person has to keep in mind that someone may want to take it apart again some day. Glass setting tape comes in various thicknesses so a person has to get something that will fit just right. Not too loose and not too tight.
Old 04-12-2020, 09:33 AM   #8
Jack Shaft
Used solex tint in a metric dimension,its stronger than 1/4" and gives a 30%reduction in UV..its like an old coke bottle tint. Set it in windshield urethane sealer,designed for easy removal if you have an issue.
