Old 03-29-2020, 02:22 AM   #1
apbright
apbright's Avatar
Default Mutant B Carb
I purchased (what I thought was) a Model B carburettor, for the purposes of acquiring a core to be re-built. I didn't look close enough, for though it has nearly the form of a Model B carb., it has some clear differences, as shown in the attached pictures. As shown in the first picture, I see
A) Something akin to an oversize secondary well (???)
B) An additional flow valve in the main bowl
C) An outlet through a different air passage, which connects to an opening on the air-side of the choke plate
D) A 'sleeve' for the main jet
Also, it does not have the traditional 'GAV' needle valve as found on A and B Carbs.
Question: Does anyone know what the carburettor is, and whether anyone sells replacement parts for it?
Thanks to all,
Andrew
apbright is offline   Reply With Quote
Old 03-29-2020, 04:36 AM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Mutant B Carb
Most likely it is a Zenith Carburetor from a tractor. Tractors usually don’t have the GAV.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 03-29-2020, 09:53 AM   #3
bphillips
Allis Chalmers used these carburetors on their early model WC tractors. They had a slightly smaller venturi and did not have the GAV or high speed enrichment circuits that the Ford B used.
bphillips is offline   Reply With Quote
Old 03-29-2020, 11:09 AM   #4
Bob C
Is there a number on the round tag on the bowl cover??
Bob
Old 03-29-2020, 12:14 PM   #5
Flathead
Flathead's Avatar
Looks like it is air balanced for an air cleaner. I have a Model A type Zenith that is like your B carb. It is not for an A or B though.
Flathead is offline   Reply With Quote
Old 03-29-2020, 05:08 PM   #6
AL in NY
AL in NY's Avatar
apbright: If you would like another Model B carb base, let me know, I have several for which I don't have an upper (it's free). Let me know if you'd like a B-1 or a B-2.
AL in NY
AL in NY is offline   Reply With Quote
Old 03-29-2020, 07:26 PM   #7
redmodelt
redmodelt's Avatar
OT; Even the Zenith Model A clone carb used on the Gleaner combine and other equipment had an air balance tube for use with air cleaner, but no GVA.
