Old 03-25-2020, 06:39 PM   #1
Dave moly
Default Serpentine belts
Can anyone tell me how fitting a serpentine belt to a model a can give it an extra 10% horsepower as claimed by Snyder’s
Dave moly is offline   Reply With Quote
Old 03-25-2020, 06:50 PM   #2
eagle
eagle's Avatar
Default Re: Serpentine belts
10% equals 4 HP, I find it a bit hard to believe a serpentine belt would make that much difference. A properly tightened V belt on a Model A will be quite loose compared to V belts on modern equipment. A cog belt is supposed to take about the same HP as a serpentine so might be a better option for a stock A. A serpentine belt has more contact area so will run a heavier load, not a problem with a stock A. I'm not an expert, just my understanding, take it for what its worth, probably less than 2 cents!
Old 03-25-2020, 06:57 PM   #3
Roxo
Roxo's Avatar
I think it's the fan blade more then the serpentine belt. The two blade fan probably moves more air therefore uses more power then that plastic 6 blade fan.
Just my 1 cents worth.
Roxo is offline   Reply With Quote
Old 03-25-2020, 07:09 PM   #4
Ruth
Just speculating but with the plastic fan they flatten out at higher speed so it does not take a much HP to turn but I don't see it increasing HP 10%. Also as the fan flattens out it allows for better air flow thru the radiator.
Old 03-25-2020, 07:39 PM   #5
40 Deluxe
You will notice that modern cars with serpentine belts run spring loaded idler pulleys to keep constant tension or preload on the belt to prevent slippage. How much belt tension can a Model A water pump take, and for how long?
As far as the claim of 10% more power, without a notarized dyno sheet, it did not happen!
Old 03-25-2020, 07:57 PM   #6
Jack Shaft
All I can say is its a slippery slope...first its a plastic fan and serpentine belt,then you put on a B carb,then a high compression head,then a weber carb with an FSI,an aries muffler and mitchell OD..convert to 12v..then thats not enough so you pop for a B block with a Serr head,juice brakes and an f100 steering box..then one day,in a moment of sobriety you look at the car and wonder where the model a went..
Old 03-25-2020, 08:51 PM   #7
Synchro909
Synchro909's Avatar
While I understand what you are saying here, Jack, I shake my head at those guys who build a hot rod with an auto transmission, Chev 350, Jag rear end, hydraulic brakes, independant suspension and modern steering, yet still call it a Model A. Ebay is full of them.
There is a rule here that says that to call a car any particular model, it must have 5 of the 7 major components that came with that model and the others period correct. he 7 components are:
  1. Chassis
  2. Engine
  3. Radiator
  4. Gear box
  5. front axle
  6. rear axle
  7. steering column
I find it interesting to note that the body is not included, yet parts of that is all some of these rods have from the Model A
As far as I'm concerned, I'm happy if someone is using their car with the modifications you mentioned rather than either cutting it up for a hot rod or leaving it rot in a shed.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-25-2020, 09:24 PM   #8
Jack Shaft
I like model a fords and I like the people who like model a fords for the most part.My point above was to make light of the quest for speed.If a person decides to buy one of these cars he's entitled to do as he wishes with it here in America,hell he can fill it with concrete and use it as a doorstop if he wants. I spent a few years of my life defending that right.
Old 03-25-2020, 10:20 PM   #9
quickchange
quickchange's Avatar
A Model A is a Model A IF KEPT WITH IN THE MAFCA MODIFIED JUDGING RULES , I think.
quickchange is offline   Reply With Quote
Old 03-26-2020, 06:07 AM   #10
daren007
I bought a model A because I wanted a model A. I will keep it a model A because of the fun driving it with all the model A nuances.
daren007 is offline   Reply With Quote
Old 03-26-2020, 11:50 AM   #11
Jim Brierley
I'm not sure of exactly what Snyder's sells with their serpentine belt, a system? At least part of the HP gain is from the extra flexibility of that belt, more flexible = easier to turn the gen & fan. I've been involved in dyno testing of performance A's, one time we took the belt completely off and I turned the water pump with a hand drill while a dyno run was made. From memory that was 3 HP. Don't recall if it had a serpentine or not?
Old 03-26-2020, 12:25 PM   #12
driving1975
driving1975's Avatar
I agree with jack shaft , waited 40 years to get a model A, and wanted to have a car close to original as could be.
The engineering is fascinating, and enjoy making machines work, was a Ford tech for 40 years and saw so many changes over those years.
driving1975 is offline   Reply With Quote
Old 03-26-2020, 12:34 PM   #13
The Master Cylinder
The Master Cylinder's Avatar
Haha, If you took the belt completely off it wouldn't make much difference if was serpentine or not.
Fine print: Sorry Jim, I mean no disrespect. I'm bored from "staying home" as ordered by the State of California. Time to go outside and inspect my nut & bolt collection again.
Stay Safe Everyone
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-27-2020, 11:07 AM   #14
johnneilson
Yes, Jim left his rear-end out in the air on this.
I take it as more of an observation that this particular motor/dyno/configuration showed only 3HP increase by completely removing the drag from waterpump/gen/fan.
Personally I find the ads claim to be pretty optimistic at best.
Before anyone points out the fact that I have one on current coupe, it was put on for the plastic fan as it can take higher rpm.
John
PS, yes, getting cabin fever, need to go for a therapeutic drive in the hills
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 03-27-2020, 12:42 PM   #15
Jim Brierley
I don't put my diff out in the cold in this kind of weather!!! The idea was to show the total power used with the belt on. Don't over-think the situation! - If the total used is only 3 HP, it is doubtful that Snyders system can save 4 HP
Old 03-27-2020, 12:48 PM   #16
100IH
Too the point where is energy being lost? the belt is thick and it takes energy to bend and straighten out (think about bending a piece of bailing wire fast: gets hot.) 2nd. belt jams itself down into the V of the pulley then has to pullout. More heat. Then add the Generator, tighter bend and another in&out. Might be some Horses eating hay. Surpentines bend with no real force and do not jam into the v to get a grip.
100IH is offline   Reply With Quote
Old 03-27-2020, 08:19 PM   #17
Chris Haynes
Chris Haynes's Avatar
Kind of like the Riley claim that their head would boost HP to 100. Dyno testing disputes that.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-27-2020, 08:50 PM   #18
denis4x4
denis4x4's Avatar
I used to write ads for speed equipment manufacturers. Wrote an ad for headers and since it was the seventeenth of the month, I claimed that the headers were good for 17% more HP. This ad appeared in CAR CRAFT and HOT ROD. Received a letter from the feds asking for proof! To make a long story short, don’t believe any sort of HP claim that you read! One exception is Jim Brierley’s HP claims for his heads and cams!
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 03-28-2020, 03:29 AM   #19
Bruce of MN
Bruce of MN's Avatar
Phil Irving https://en.wikipedia.org/wiki/Phil_Irving said that BHP stood for Brochure Horse Power.
Old 03-28-2020, 09:16 AM   #20
johnneilson
That's a good one, I'll have to remember that
J
The other factor is that dynos require calibration and "correction" for air characteristics. It is amazing how many claims are just "over corrections".
