Old 12-29-2019, 03:40 PM   #1
1939 Mercury
Default 39 Ford/Mercury parts
What will work in a 39 Mercury from a Ford? It dosent have to look correct just work like it should. Examples are door latches and window regulators, knobs handles etc..
Thanks guys and gals!!!
1939 Mercury is offline   Reply With Quote
Old 12-29-2019, 04:27 PM   #2
marko39
Default Re: 39 Ford/Mercury parts
Get a copy of the "GREEN BIBLE it will tell you all you need.
marko39 is offline   Reply With Quote
Old 12-29-2019, 05:24 PM   #3
1939 Mercury
Thank you I have never heard of it so i will have to look
Old 12-29-2019, 05:57 PM   #4
JSeery
JSeery's Avatar
If you get the correct CD it has something like 13 different manuals on it.
Old 12-29-2019, 07:21 PM   #5
rotorwrench
rotorwrench's Avatar
A person really needs the original 1938 thru 41 Ford & Mercury chassis parts book too. It gives the original part numbers for the 99, 09, & 19 Mercury cars with the longer wheel base.
The body is where most of the differences are. The designs have similarities but they are not the same. As far as door hinges. latches, window regulators, and stuff like that, a person just has to ask someone with experience with a specific year and body type. Some of those parts may be similar but I certainly don't know.
Old 12-29-2019, 08:01 PM   #6
Flathead Youngin'
Is the CD searchable with a search bar?
"Constipated, can't pass a thing! Don't laugh, bud, your daughter may be in here. They don't call 'em flyn' flatheads for nothin'!"
Hot Rod (Kennie) Holmes
Flathead Youngin' is offline   Reply With Quote
Old 12-29-2019, 10:35 PM   #7
JSeery
JSeery's Avatar
The CD is in PDF Format.
Old 12-29-2019, 10:56 PM   #8
Clem Clement
Clem Clement's Avatar
The cars are different size so lots of things almost fit not. I'm struggling with 40Merc parts at the moment. I have a air gap in the hinge end of the door on the Fodor convert sedan and can't find a part number or drawing
Old 12-30-2019, 03:10 PM   #9
Karl Wescott
Karl Wescott's Avatar
The "Green Bible" is of chassis parts and will be of little help with body parts... You need a copy of the 1939 and 1940 body parts books.
As to what "will work" is a matter of trial and error and opinion. Most (but not all) 1932-40 inside door and window handles will fit any square shaft 1932-40. Bungee cords will work as a door latch for most anything... but are not confided "couth" by most!
Even within 1939 Mercury body parts there are major differences, Convertibles, Coupes, Sedans and Sedan Coupes ("hardtop") all share some parts and all have unique parts that may simply not work with another body style.
Try asking specific questions here... 1939 Mercury (body style?), and the specific part you are needing.
Karl Wescott is offline   Reply With Quote
Old 12-30-2019, 10:50 PM   #10
JSeery
JSeery's Avatar
Karl, the 39 & 40 body parts books are on the disk.
