I started putting my floorboards back in my 35 pickup after locating the source of my whomp whomp. Got the metal toe board back in and fastened down. Started to put the shift lever back in and dropped the *&$()^ pin down into the innards. Took floorboards back out, took the top off of the transmission and spent quite a while fishing around in the bowels of the transmission with a magnet and finally got it out. I must have said the right curse word or something, but I got the metal toe board and shifter back in and called it a day. That's the first time that ever happened to me. I guess I am just lucky. Whew!!! Time for a drink. lol
C'mon Lawson, you know you're having fun!
Imagination is more important than knowledge. |
Fenton Cast iron headers, what a nightmare! Just finished complete dual exhaust with Fentons and glass packs, now it finally sounds great! The right side took less than an hour, easy, the left side took 2 days! I'm not sure a muffler shop would even want to mess with it, and I couldn't afford it anyway, so it is a DYS job at home in a garage. Not pretty but sounds great!
Lawson, you are lucky, i would have to take the truck apart to get it out.
i had a 64 GMC pickup, one time i rebuilt the carburetor, while i was putting it back on i lost a nut on the top of the motor, i could not find it so i got a nother one. about a year later i was tuning-up the motor, new points, and plugs, i could not get one in. the motor was a V6 the plugs point straight up and they are in the valley of the motor. the nut was in the spark plug hole i was able to get it out by threading a bolt into it . it could have been a nightmare!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
Did the v-6 thing back in 68 on a GMC 4000 with a 351. Doing a tune up after a snow storm, took out plugs, replaced them and points. Started up with a LOUD knock. We took intake and cylinders off and discovered a small sheet metal screw had dropped through a plug hole. Lots of accumulated crud in the intake valley.Screw was really indented into the top of the piston. Always wondered what would have happened if we just let it run? Maybe flatted out enough so noise goes away? I suggested that but at 18 nobody listened. Those were rugged engines.
He is saying that if you punch up the hole on the transmission cover where the pin goes to make it a tight fit.
I fix the loose fit in the top by getting a drill bit that is a press fit and cutting the bit to the length as necessary and inserting it. |
Yeah, I could do that I guess. Next time I have the pin out, which I hope is a long time from now, I will use a cut off drill bit.
