Old 12-11-2019, 08:51 PM   #1
fred93
fred93's Avatar
Default 29 Tudor upholstery question
I am working on installing the upholstery on the 29 Tudor. Back in 2017 I purchased a pre-cut unfinished panel set from LeBaron Bonney. So far I have had two issues. The first issue (which I have rectified) was that the large panel that goes under the side rear window each had two holes-one is for the window crank and the other I have no idea why it is there!
The second issue is that the panel that goes in the rear corners between the back window and the rear side window seems to be different than the one that had been on the car. I have no idea if the old panel was original or was it replaced sometime in its life.
Please look at the photos that I have attached and give me your thoughts. I plan on installing the old panels to see how they look and then putting the new ones up to see how THEY look. I don't want to start trimming the new panels to match the old ones until I know for sure that I am doing the right thing.
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
