Old 11-23-2019, 05:40 PM   #1
adileo
adileo's Avatar
Default Draining tank
Hi all
As previously mentioned. In need to remove the 39 gas tank and send out for cleaning. My plan was put car up on lift and attach a 5/16 hose from fuel filter (prior to electric pump) to my 52 pickup gas filler and have gravity do it’s thing. The problem is it’s just dribbling in (btw gas cap was off car to help).
There is a drain plug under the tank. The problem is, I drain that way I’m sure a lot of crap will come out with the gas.
I have lil over half a tank. So I’m thinking....can I pull drain plug and then use pantyhose and then pour in truck tank? I don’t want crap in truck tank.
Open for suggestions
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 11-23-2019, 06:52 PM   #2
4t7heaven
Default Re: Draining tank
Just install an inline filter to the drain hose that you're using.
4t7heaven is offline   Reply With Quote
Old 11-23-2019, 06:54 PM   #3
adileo
adileo's Avatar
Thanks I have that and it’s just dribbling out. Assume passage way to inline filter blocked prior to filer. There is no fitting to attach at drain plug.
Thanks
Andy
1952 F1
Old 11-23-2019, 08:17 PM   #4
JSeery
JSeery's Avatar
Why do you care what comes out with the gas? It is easy to filter it before using it for something else.
Old 11-23-2019, 08:28 PM   #5
adileo
adileo's Avatar
Jerry thanks that was my question
Pantyhose in filler of truck? Or?
Thanks
Andy
1952 F1
Old 11-23-2019, 11:06 PM   #6
JSeery
JSeery's Avatar
I would filter it from one container to another before putting it in the tank. Just be careful with the stuff! The filter material you use would depend on how fine of material you are wanting removed.
Old 11-23-2019, 11:14 PM   #7
tomcarman
tomcarman's Avatar
I'm certainly no expert, however if I were in this situation I would let it dribble out through the filter as you are doing now. What's the hurry afterall. I would not use pantyhose as I would be quite concerned the gas would dissolve or otherwise degrade the material leaving contaminates in the fuel. If you are in a hurry then by all means pop the drain plug and empty into a gas can. The worst that can happen is you may waste about $20 worth of gas, or perhaps you could find an appropriate conicle filter and pour the gas from one can to the other thereby inspecting the contents of what's in there as you go.
tomcarman is offline   Reply With Quote
Old 11-23-2019, 11:28 PM   #8
paul2748
paul2748's Avatar
I have used cheescloth for filtering. It works very well.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-24-2019, 08:08 AM   #9
adileo
adileo's Avatar
Thanks all. The dribbling could take hours and I don’t want to leave unattended.
Thanks
Andy
1952 F1
Old 11-24-2019, 10:23 AM   #10
deuce_roadster
deuce_roadster's Avatar
I have successfully used 2 nested conical paint filters for gas. I am at a loss to understand why you would want to leave junk in your tank. It sounds to me like it needs to be boiled out or replaced as well as the hardline up to the engine.
Old 11-24-2019, 10:56 AM   #11
adileo
adileo's Avatar
Guess you didn’t read my first post...
Thanks
Andy
1952 F1
Old 11-24-2019, 12:44 PM   #12
Brian
Brian's Avatar
Why not simply use drain plug, run into a suitable sized container....then decant into another container/ truck's tank, using a filter medium in a funnel
Old 11-24-2019, 01:20 PM   #13
cmbrucew
cmbrucew's Avatar
why would you not use the electric pump to transfer the fuel using the filter already in place?
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 11-24-2019, 02:53 PM   #14
adileo
adileo's Avatar
Good suggestion. Tried the blockage was in the tank. The pump could not pull it through. I got it now pulled plug.
Thanks all for advise.
Thanks
Andy
1952 F1
Old 11-26-2019, 08:11 AM   #15
Mike51Merc
Mike51Merc's Avatar
Siphon out through the filler tube to get the majority out, then remove the plug to get the rest.
Mike51Merc is offline   Reply With Quote
