Can the stock 37 ford cam be reground close to an isky max1 3/4 cam ? Or what is a good sounding cam for a 21stud motor that will have sharp heads on it. Thanks all.
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
We like the Isky 77B cam grind.
Can the stock cam be ground to that ?
I don’t see why not. I have re-ground several of those early cams to my KiWi-L100 specs.
Kiwi do you still grind them. I’m looking for someone to do one.
just curious, Does the cam you have ,has apressed on timing gear.????? Most any cam Grind can be put on a stock cam. Which brings up the application and cost. When re grinding a stock cam, you will have to use adjustable lifters, or longer valves. Also in a stock engine, longer duration reduces low end torque The 77B is very much like a stock grind$$$$$ for changing the cam you must have a good reason.
Ron I’m going with the 1007B cam. The cam I believe is the press on timing gear. With that cam it will have Sharp heads and dual carb intake. Im on the fence on the adjustable lifters, if i run them I will have to make jam nuts for them or just get longer valves and cut them to what I will need.
The 1007B is a really good cam - you'll like it in that engine! I tend to run Chevy valves - as I like the longer length. I then make custom spacers for the guides (depending on the cam, springs and how much spring pressure I want on the seat).
Curious about your Sharp heads. Are they original? Sharp 21 stud hmmmmm any pics of them or history.
Cheers TP |
Kiwi. Repop from h&h. I believe they are about 8:1 compression ratio.
Ah okay they look great but Sharp never made 21 stud heads like that. I have a laaaarge Sharp collection.
Cheers |
#13 |
Well if I come across someone wanting to give up Evans or cyclone 21 stud heads instead of letting them sit on their shelf I’ll take those too. Hahah.
#14 | |
![]() Quote:
Happy TurkeyDay to Yah! |
#15 | |
![]() Quote:
My super popular KiWi-L100 cam originated from your great state of Rhode Island. Cheers |
#16 | |
![]() Quote:
And a Happy Turkey day to yourself. Cheers Tony |
