Old 04-24-2019, 08:59 PM   #1
Nlbloch
Default Lubrication chart in Les Andrews' book
At the end of Les Andrew's book (pages 3-4 and 3-5) there are some very useful lubrication diagrams with letters and numbers. However, I can't find a legend for the meaning of the letters or numbers -- which I would find helpful. Any ideas? Alternatively, any other good suggestions for Spring lubrication guides and overall maintenance checklists?
Separately, one of the guides I am using suggests to "remove the bell housing cover" and lubriacate. I'm not sure what the "bell housing" is and where to locate it.
Nlbloch is offline   Reply With Quote
Old 04-24-2019, 09:20 PM   #2
Brian SATX
Brian SATX's Avatar
Default Re: Lubrication chart in Les Andrews' book
For the bell housing one, remove the floor boards. You will see a large item that looks like a bell, and it will have a vented cover held on by two screws. Loosen the screws and remove the plate. Look inside and you will see a zerk fitting. Grease it.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 04-25-2019, 05:33 AM   #3
springerpete
springerpete's Avatar
Look on pages 3-2 and 3-3.
springerpete is offline   Reply With Quote
Old 04-25-2019, 06:55 AM   #4
Werner
Werner's Avatar
Therefore, I think do you mean.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-25-2019, 10:37 AM   #5
chap52
chap52's Avatar
Yep, that's it. Chap
Old 04-25-2019, 01:57 PM   #6
Chris Haynes
Chris Haynes's Avatar
I have seen later V8's with a grease cup on the cover. You just need to give it a turn to push fresh grease into the throw out bearing. Could this be adapted to a model A?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-25-2019, 03:45 PM   #7
Werner
Werner's Avatar
Hallo Chris,
I think, you mean this one? If, yes, that is an option. But you must use a heat-resitant grease!
Werner
Citroen 11 CV, 1947
Old 04-25-2019, 04:14 PM   #8
Nlbloch
Thanks, everyone, for your replies. That has to be the most difficult zerk fitting. My 1930 coupe has a rubber floor mat which has been riveted into place at the top. So to access the opening, I must lift the floormat half way, raise the gear shift and parking brake rubber floor gaskets, and stick my hand deep inside. Surely there must be a better way -- but I couldn't find one.
Now that this is done, I must ask: what is being lubricated in the bell housing?
Old 04-26-2019, 06:38 AM   #9
Brian SATX
Brian SATX's Avatar
Throw out bearing is what is in the bell housing.
Brian SATX
Old 04-26-2019, 02:07 PM   #10
100IH
The actual bearing is a ball bearing and it will take the the grease. The bearing is lightly pressed on to the sliding carrier for the T/O bearing. Some of the grease will go to the inside of the T/O carrier where it slides in and out to actuate the clutch disengagement. The carrier is sliding on the snout that is on the front bearing carrier. Note: many of the newer replacement T/O bearings do not have the channels for the grease, permanent lube for the bearing and no lube, I think, for the sliding of the carrier on the bearing retainer snout.
100IH is offline   Reply With Quote
Old 04-27-2019, 10:04 AM   #11
katy
katy's Avatar
IIRC, those V8s had a flexible hose between the fitting for the grease cup and the fitting for the release (throwout) bearing.
Old 04-28-2019, 07:50 AM   #12
26 Coupe
Is there any danger of putting too much grease in the throwout bearing and getting some on the clutch surfaces?
26 Coupe is offline   Reply With Quote
