Old 04-23-2019, 10:24 AM   #1
Sid
Sid's Avatar
Default Brake light pressure switch
On the 40 Ford brake light switch design is there a difference in a 12 V switch and a 6 volt switch? Does any one have a Napa part number for a switch for the 40 Ford 6 Volt?
Sid is offline   Reply With Quote
Old 04-23-2019, 10:35 AM   #2
TJ
TJ's Avatar
Default Re: Brake light pressure switch
A switch is a switch when it comes to the brake lights. Those pressure switches were used for years, so your local Napa store should have it in stock.
Old 04-23-2019, 10:44 AM   #3
Sid
Sid's Avatar
Thanks....I thought so. I had just noticed them listed on evil bay 39-48 Ford. I know G.M. and Ford used them into the 60's.
Old 04-23-2019, 11:05 AM   #4
1931 flamingo
1931 flamingo's Avatar
I believe some use a switch from a motorcycle.............
Paul in CT
Old 04-23-2019, 11:29 AM   #5
tubman
tubman's Avatar
Paul in CT
I have heard this as well. Some say that the switches Harley-Davidson uses are higher in quality than the after-market units. I've never had a problem, so I have no personal knowledge.
Old 04-23-2019, 11:55 AM   #6
4dFord/SC
4dFord/SC's Avatar
Years ago, I went to a mechanical switch mounted to the toe board behind the brake pedal. I found it to be much more responsive than the stock switch. As I recall, it's a brake light switch for a 1950 Chevrolet that I got from NAPA.
4dFord/SC is offline   Reply With Quote
Old 04-23-2019, 12:40 PM   #7
19Fordy
19Fordy's Avatar
Here's a helpful thread.
https://www.fordbarn.com/forum/showt...e+light+switch
I am using a Harley Davidson 12V switch. Works fine for past 10 years.
https://www.ebay.com/sch/i.html?_fro...ch&_sacat=6000
