03-31-2019, 07:58 PM | #1 |
Recomended torque?
What is the recomended torque for the bolts that attach the torque tube to the differential?
Thanks. Pluck |
03-31-2019, 08:39 PM | #2 |
Re: Recomended torque?
9/16's wrench, about 8" long. Pull tight but not jack-the-bear tight!
03-31-2019, 10:36 PM | #3 |
35 fp
I know the voices aren't real but damn they have some good ideas! |
03-31-2019, 10:41 PM | #4 |
04-01-2019, 02:09 AM | #5 |
35 ft. lbs. is recommended in most documents. It is the same as the 20 banjo bolts, which are the same thread size.
When installing theses bolts I want them to be tight, but also lined up so the safety wire forms a perfect circle. To do this I have an ample supply of bolts and through trial and error and swapping them around I can get them tight and lined up. The photo shows my trade mark. It may not be according to Henry, but I think it looks better. Tom Endy |
04-01-2019, 03:59 AM | #6 |
Gerry, Birch Bay WA |
04-01-2019, 05:38 AM | #7 |
Thank you guys...Much appreciated...35 ft. lbs. it is.
Pluck |
04-01-2019, 07:02 AM | #8 |
Banjo bolts are "special." Class fit is "tighter" than usual to prevent oil leak. You can't (shouldn't) use common bolts without RTV or other sealant, and run the risk of stripping them out as common bolts are undersize in comparison to the holes. Torque tube bolts may be the same.
Joe K
Shudda kept the horse. |
04-01-2019, 08:09 AM | #9 | |
