Old 02-10-2019, 11:01 AM   #1
ct1932ford
ct1932ford's Avatar
Default 30-31 windshield vs 32
How close is a 30/31 windshield to a 32? Also anyone making a 32 windshield that is like the original i.e.: a bit more rounded than the repops I see out there?
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 02-10-2019, 11:20 AM   #2
DavidG
DavidG's Avatar
Default Re: 30-31 windshield vs 32
If you mean for a phaeton/roadster, not even close given that your concern seems to the cross section of the frame.
Old 02-10-2019, 11:25 AM   #3
skidmarks
skidmarks's Avatar
The only model A windsheild that fits a 32 in shape and size is the truck. And it fits 33 34 but the bottom of the frame on a model A has a lip that has to be cut off
Nothing else is the same like a roadster ect
skidmarks is offline   Reply With Quote
Old 02-10-2019, 12:23 PM   #4
ct1932ford
ct1932ford's Avatar
Yes the cross section on the repops do not look close to an original.
Old 02-10-2019, 02:05 PM   #5
DavidG
DavidG's Avatar
The ones from NC Industries in Pennsylvania are very good and a cut above the others.
Old 02-10-2019, 04:05 PM   #6
Karl Wescott
Karl Wescott's Avatar
The 1932(-34) roadster pickup uses the same windshield frame as the 1930-31 standard roadster/phaeton.
As noted the 1932(-34) closed pickup has a similar tubing section to the 1926-31 closed car, however the shape and dimensions are very different.
Everything else is not close.
Karl Wescott is online now   Reply With Quote
