Old 01-05-2019, 08:43 PM   #1
doa44green
Default Zenith 2 mystery
The fuel in the bowl, at 5/8 " from gasket surface, wicks up to the gasket surface and floods over to the outside of the bowl. Has anyone ever experienced this situation? Is there a sealer suitable for the inside of the float bowl? Any assistance will be greatly appreciated!!
Thank you very much in advance!!!
Don
doa44green is offline   Reply With Quote
Old 01-05-2019, 10:08 PM   #2
James G.
Default Re: Zenith 2 mystery
where do you see the leak occurring? hard to believe gas would wick between the two castings through the gasket. The assembly bolt must not be tight, or, the mating surfaces of the two castings are not flat.
James G. is offline   Reply With Quote
Old 01-05-2019, 10:08 PM   #3
Brentwood Bob
Sounds like the casting may be cracked, or porous.
Try soapy water and some air in the fuel inlet with the gaskets in place and the carb bolted together.
Also make sure the gasket surface between the top and the bottom castings are flat.
The threads of the gas inlet may also be bad, or the mating surface is damaged.
Brentwood Bob is offline   Reply With Quote
Old 01-05-2019, 10:11 PM   #4
Gary WA
Gary WA's Avatar
No Sealer! Check float Height?Make sure all jets are tight with washers. no washer on ldle jet.http://modelabasics.com/home.htm
www.whidbeymodelaclub.com
Old 01-06-2019, 12:18 PM   #5
Bill Cilker
Bill Cilker's Avatar
The fuel inlet valve may be leaking slightly allowing the fuel level in the bowl to reach the gasket between the 2 pieces.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 01-06-2019, 01:34 PM   #6
redmodelt
redmodelt's Avatar
If that were the case it would be leaking out the jet before it reached the rim.
Old 01-06-2019, 01:40 PM   #7
ModelAMike1930
ModelAMike1930's Avatar
Some of the repo bowl gaskets were too thin and caused the carb to leak. I had that problem and replaced the bowl gasket and it solved my problem.
ModelAMike1930 is offline   Reply With Quote
Old 01-06-2019, 09:26 PM   #8
doa44green
I have the bowl separate from the top and held in a vise.
The gas wicks up the inside and overflows to the outside. I have this experience with two separate bowls.
Old 01-06-2019, 10:17 PM   #9
Brentwood Bob
I have seen a crack in the casting on the bowl side where the main bolt is.
Also in the area between the secondary well and the main bolt.
Have your castings been treated with a derusting solution?
Difficult for me to reason out your wicking problem.
Old 01-06-2019, 10:41 PM   #10
Fred K-OR
Fred K-OR's Avatar
Are you sure the gas comes from inside the bowl? Could it be leaking where the inlet pipe goes into the carb. I have had this happen and the gas flows around the gasket between the bowls and it looks like it is coming from inside.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-07-2019, 12:10 AM   #11
redmodelt
redmodelt's Avatar
Someone within the last year had the exact same problem including holding it in a vice.
https://www.fordbarn.com/forum/showthread.php?t=244374
