Old 12-13-2018, 02:31 PM   #1
Chiefguy
Chiefguy's Avatar
Default New to Model A
Hello. I was advised to get on this forum and introduce myself.
I am retired and just bought an old Model A Ford or Sedan.
Problem.....engine is frozen. I have been soaking pistons with mystery oil and ATF. No luck.
The car is otherwise nice.
Ideas?
Chiefguy is offline   Reply With Quote
Old 12-13-2018, 02:54 PM   #2
Licensed to kill
Licensed to kill's Avatar
Default Re: New to Model A
A friend of mine was given a flathead that was seized. he soaked the cylinders with penetrating oil for over a week with no luck. He then put vinegar in the cylinders and the motor turned over by hand (with resistance) the next day.
Licensed to kill is offline   Reply With Quote
Old 12-13-2018, 03:08 PM   #3
JOHN CT
JOHN CT's Avatar
How long have you been soaking the cylinders? Are you trying the crank or starter to spin it over? ATF is a good solution but i never mixed it with Marvel mystery oil. Trying mixing the ATF with acetone and get a socket and a breaker bar on the crank pulley nut. That helps to get better movement.
I’ve freed stuck motors that way. Just have patients.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 12-13-2018, 03:15 PM   #4
copgib
copgib's Avatar
it sounds like it is now a waiting game. Let the chemicals do there job. It will free up! Hugh
copgib is offline   Reply With Quote
Old 12-13-2018, 03:29 PM   #5
1930artdeco
1930artdeco's Avatar
Welcome to the Barn! How about some Pics?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 12-13-2018, 03:55 PM   #6
Chiefguy
Chiefguy's Avatar
Thank you for all the interest to help!
I will continue to pour ATF into the one cylinder that it takes over night to drain out of. The other three seem to drain down in 15 mins or so.
I will try conifer next week...lol
Thanks guys
I pulled the car today...third gear...left skid marks both rear wheels.
Old 12-13-2018, 04:12 PM   #7
WHN
Give it some time. Rome wasn’t built in a day.
Also check other things that could be holding things. Is your Starter stuck, also take off valve cover and check if valves and lifters are free to move. Another place to use MMO.
Keep us informed. Enjoy.
Old 12-13-2018, 04:26 PM   #8
Chiefguy
Chiefguy's Avatar
Yes, been soaking a week. Been jumping on hand crank, and pull/dragged her today. No luck.
Old 12-13-2018, 04:32 PM   #9
Charlie Stephens
Thanks guys
I would be worried about bending rods and breaking gears if I pulled it to get it turn over. Take it apart and fix it right.
Charlie Stephens
Old 12-13-2018, 04:36 PM   #10
Chiefguy
Chiefguy's Avatar
Thanks friend. Going to try your path next. I do have time....I think. Lol
Old 12-13-2018, 04:38 PM   #11
Steve Plucker
Is the clutch froze up on the flywheel?
Pluck
Old 12-13-2018, 04:47 PM   #12
WHN
Charlie Stephens
Charlie’s right. Don’t take a chance on breaking other things that aren’t now broken.
As I mention, get some (a lot) penetrating oil on your valves and lifters, cam and bearings. Valve cover should come off now.
Is there rust on cylinder walls?
Does car roll freely when in neutral.
How long has it been since the engine was last started?
Picture of engine would help.
Old 12-13-2018, 04:52 PM   #13
Chiefguy
Chiefguy's Avatar
I had a spinal cord trama five years ago. Big jobs are out of my capabilities these days
But thank you for my friend
Old 12-13-2018, 04:59 PM   #14
Chiefguy
Chiefguy's Avatar
The car does roll freely. I:ll try to get pics soon. Car is 45 miles away, so don't get there everyday.
I was told engine ran 3 years ago.
There is black crud on pistons, but couldn't tell if rust.
When I pulled plugs, looked like she had run last couple days.
Having trouble finding how to post car pics
Old 12-13-2018, 05:06 PM   #15
Chiefguy
Chiefguy's Avatar
Did my pictures go thru.
I am lost at this
Old 12-13-2018, 05:15 PM   #16
1930artdeco
Yep you have a nice late 30 Briggs Fordoor.
Mike
1957 Country Sedan
Old 12-13-2018, 05:16 PM   #17
Chiefguy
Chiefguy's Avatar
Like your sedan Mike
Old 12-13-2018, 05:16 PM   #18
WHN
I am lost at this
Got the pictures.
Take some of engine, might help in understanding condition of engine. Left and right side, plus top.
Car looks like your going to have fun. We just have to get it running.
Old 12-13-2018, 05:18 PM   #19
Chiefguy
Chiefguy's Avatar
Clutch and trans feel good
Old 12-13-2018, 05:22 PM   #20
Chiefguy
Chiefguy's Avatar
Going to sign off for now. Back later...or tomorrow.
Thanks guys
