Old 11-12-2018, 04:08 PM   #1
zzlegend
zzlegend's Avatar
Default New pistons, what brand?
Looking for any advice on a set of new pistons for my 46, 59AB that i am rebuilding. 80 over. Much difference in brands out there? What have you guys used?
zzlegend is offline   Reply With Quote
Old 11-12-2018, 04:10 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: New pistons, what brand?
Egge
Old 11-12-2018, 04:13 PM   #3
flatford39
I used EGGE as well. You can get them from Van Pelts. Just make sure you give them to your machinist so he can measure them before boring the cylinders out.
flatford39 is offline   Reply With Quote
Old 11-12-2018, 04:14 PM   #4
papanomad
papanomad's Avatar
egge from van pelt, and they have .080.
papanomad is offline   Reply With Quote
Old 11-12-2018, 05:28 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
Egge is really your only choice theres not to many manufacturers making pistons for the flathead anymore. Egge is the best for a cast piston.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 11-12-2018, 05:48 PM   #6
Mac VP
Mac VP's Avatar
Unless you’re fitting a Mercury 4” crankshaft to this motor, the regular 8BA pistons are what you want for your engine. As stated already, we stock the Egge brand. We’ve got the matching ring sets on hand as well.
Make sure your machine shop has completed the boring process on the block before you order the pistons. This will assure you and him that the overbore will clean up the cylinders adequately. Sometimes they’ll find that there was a deep scratch or gouge that reqired a slightly larger bore than they thought originally.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-12-2018, 06:12 PM   #7
zzlegend
zzlegend's Avatar
Thanks for all the reply's guys. Egge was one i was going to check with.
Mac, i have the motor at the machinist now and he magged it and looked it over and said the same as you. He is going to bore it and just wanted to make sure what pistons were available. He thinks it will clean up at 80 and said he would do a final fit after i get the pistons. I will be in touch with you as soon as i hear from him. Thanks again.
Old 11-12-2018, 06:59 PM   #8
philipswanson
This is the opposite of conventional wisdom. Most machinists say never bore until you have pistons in hand to get the best fit. It's harder to buy a piston to fit a particular bore than vice versa.
philipswanson is offline   Reply With Quote
Old 11-12-2018, 07:02 PM   #9
JSeery
JSeery's Avatar
I took it as cut to a slight undersize to see if the cylinders will clean up and then final fit with the pistons in hand.
Old 11-12-2018, 07:04 PM   #10
zzlegend
zzlegend's Avatar
That's how i read it also. That's what my machinist was going to do.
Old 11-13-2018, 06:02 AM   #11
Mac VP
Mac VP's Avatar
You have stated it correctly. I just wanted to caution him about ordering the pistons before they’ve established that the cylinders are okay. I tell everyone this now. I also tell the customer to keep the pistons (and the rings) in their unopened boxes until the shop is ready to fit them. We’ve had to deny some returns over the years that were sent back in opened, greasy boxes, with dirty fingerprints all over the new pistons.
VANPELT SALES LLC
Cincinnati, Ohio
Old 11-13-2018, 04:46 PM   #12
flatford39
You can get them at Ross Pistons as well I think but they are a lot more expensive. Ross makes pistons for race motors so you probably don't need that.
Old 11-13-2018, 06:37 PM   #13
Ronnie
Ronnie's Avatar
Silvolite 1058 United machine still make them also have all the oversizes.
https://uempistons.com/p-20-silv-o-lite.html
1003p Sealed Sower as well http://www.sealedpowervintage.com/parts-lookup/
R
Ronnie is offline   Reply With Quote
Old 11-13-2018, 07:01 PM   #14
zzlegend
zzlegend's Avatar
Thanks flatford. Ya, Ross might be a little much for what i am doing.
Ronnie, i have seen those silvolite's but have not inquired about them yet. I sent a P.M. to Mac and just waiting to hear back from him. Had a couple of questions for him.
Old 11-13-2018, 07:04 PM   #15
rotorwrench
rotorwrench's Avatar
Sealed power also still makes the old dome top 4-ringers. They are getting pricey to some extent but aren't they all.
Old 11-13-2018, 10:03 PM   #16
Ronnie
Ronnie's Avatar
1-800-648-7970 Call Silvolite tech services that is what they are there for
R
Old 11-14-2018, 07:53 PM   #17
zzlegend
zzlegend's Avatar
rotor, yep, seems like everything is getting some what costly. Dare i say,,,,,i use to rebuild a small block 265,283,chevy for 3 to 5 hundred.
Ronnie, thanks for that info.
Old 11-14-2018, 10:05 PM   #18
Ol' Ron
Ol' Ron's Avatar
I'd bore it to 3 5/16 and use Egge 3 ring pistons and gain another point in compression and 258 CI. Don't be bashful.
