Old 09-04-2018, 08:04 PM   #1
Jasper
Default Model a rear end
Hi. I知 a new guy from Nevada and I知 not very computer literate so my son helped me get set up here. My grandpa bought 29 pickup new and I知 the second owner. I drove it to school in high school years. That was 50 years ago and now I知 restoring it. I知 doing all my own work but I need a little guidance from time to time. Hope you guys can help. The axles on both sides have maybe an eighth of an inch wiggle up ab down, not end play. Is this normal and the bearing and tapered shaft carry and center it or do I need to disassemble and replace parts. Thanks
Sent from my iPad using Tapatalk
Jasper is offline   Reply With Quote
Old 09-04-2018, 08:29 PM   #2
Terry, NJ
Terry, NJ's Avatar
Default Re: Model a rear end
Yes, When the drum is off. Look inside your drum and look at where the bearing rides and you'll see how it was designed. The rear axle bearing rides on the protrusion sticking out from the axle housing. Take the drum off and the axle becomes "free Floating".
Terry
Old 09-04-2018, 10:33 PM   #3
CWPASADENA
CWPASADENA's Avatar
If you have not already done so, I would purchase the Model A Mechanics Handbook by Les Andrews. There are 3 volumes. Vol 1 would be most useful but I would suggest buying all 3. These are available from most Model A Parts suppliers such as Bert's in Colorado or Brattons on the East Coast.
Good luck with your project and welcome to The Barn.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-05-2018, 12:43 AM   #4
quickchange
quickchange's Avatar
Where in Nevada, Joe Callahan Carson city , Concours parts, If you need help , if not the books above are the best for dyo , Spring day in NZ
quickchange is offline   Reply With Quote
Old 09-05-2018, 01:42 PM   #5
1931 flamingo
1931 flamingo's Avatar
Welcome ! ! !
Paul in CT
