08-29-2018, 07:38 AM | #1 |
Grounding the Battery to the Block 51 F1?
I have converted my 51 F1 with 239 flathead V8 to 12V negative ground. I need to connect the ground battery cable to the block. I know that under a head bolt is the most common location, but I'm not sure which one to use. I have head bolts, not studs, and I don't want to drain the antifreeze just to remove a head bolt.
Are any of the head bolts on the passenger side of the block NOT into the water jacket? Been so long since I rebuilt the motor that I don't remember. Thanks. |
08-29-2018, 07:43 AM | #2 |
Re: Grounding the Battery to the Block 51 F1?
A head bolt would work, but belive I would look for another ground location on the block. Be sure any location is clean bare metal, and I would use a grease to keep it that way.
08-29-2018, 07:50 AM | #3 |
connect the ground to a bolt on the bell housing adapter, easy to do
08-29-2018, 07:59 AM | #4 |
Or one of the coil bracket mount bolts, assuming the battery is on the passenger side.
08-29-2018, 08:21 AM | #5 |
I have them connected to an intake manifold bolt.
08-29-2018, 10:59 AM | #6 |
08-29-2018, 01:48 PM | #7 |
Another good ground location is one of the 4 unused threaded bosses on the front lower block, where early V8 (and '53 truck) motor mounts were bolted to.
