Old 07-24-2018, 07:20 PM   #1
Tom Smith
Default 1949 F8 Steering Wheel
Need to remove the steering wheel, to remove column from truck. Found that the column box will not fit up through floor. Any suggestions.
Tom Smith is offline   Reply With Quote
Old 07-25-2018, 04:00 AM   #2
big job
big job's Avatar
Default Re: 1949 F8 Steering Wheel
I just did one. 3 choices stand up and wiggle wheel while someone whacks the shaft
(protect the threads) 2nd bearing separator with a big puller 3rd drill and tap the
wheel for a puller 4th good luck. I used the bearing separator and lucked out, just be
careful . I bought maybe the only NOS in a box in the world F8 wheel.....sam
big job is offline   Reply With Quote
