Old 07-03-2018, 12:09 PM   #1
Cape Codder
Cape Codder's Avatar
Default Valve Adjustment Needed?
I have approx 9700 miles on a motor that was completely rebuilt. I have never adjusted the valves. Will the engine, while driving, give me some indication that the valves need adjustment?
Cape Codder is offline   Reply With Quote
Old 07-03-2018, 02:24 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Valve Adjustment Needed?
They most likely won't need any adjustment until the valves are lapped, If you hear strange tapping you might check on things then also.
Old 07-03-2018, 02:34 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
So if the cam or lifters wear, then the gap would get larger?
If the valve recedes into the seat or block, the gap would decrease, possibly burning a valve?
Old 07-03-2018, 03:08 PM   #4
J Franklin
J Franklin's Avatar
Those things could happen with faulty parts, improper maintenance, or misuse. Not likely if cared for and driven nicely. Check valve adjustment any time the engine is opened up or valves worked on.
Old 07-03-2018, 04:55 PM   #5
Patrick L.
Patrick L.'s Avatar
An engine could give some indication of a need for a valve adjustment, but, not always. If they get noisy then its time for one, but, slightly noisy/loose valves won't hurt anything. If they tighten themselves they'll stay quiet and could cause damage.
If you're thinking about this, then why not check them. its not that hard to do and they are not always set correctly when the engine is assembled. You'll know what you have when your done.
Old 07-03-2018, 09:39 PM   #6
Cape Codder
So there is no set time schedule to set the valve clearance?
Old 07-03-2018, 11:05 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
Ideally the lifter/cam/valve stem tip wear equals valve/seat wear and the clearances stay good for the "life" of the valve job ---from the looks of the wear on some of the engines taken apart it went for a long time,
Old 07-04-2018, 07:17 AM   #8
WHN
Every engine wares differently. I would guess there are engines out there that have many, many miles on them and have never had a value job or adjustment.
We own a Model A with an engine that was redone in the mid 1940’s. No valve noise, good compression (all in the mid 60’s), no smoke, runs strong. I just always recommend regular oil changes and STP. Cheap engine insurance. Enjoy.
Old 07-04-2018, 08:11 AM   #9
George Miller
George Miller's Avatar
When new there was no adjustment on the valves. They were set when new, they stayed that way until it needed a valve job.
George Miller is offline   Reply With Quote
Old 07-04-2018, 09:48 AM   #10
redmodelt
redmodelt's Avatar
Adjustable lifters not installed?
Old 07-04-2018, 11:45 AM   #11
Cape Codder
I do have adjustable lifters and that is why I asked the question.
Old 07-04-2018, 12:44 PM   #12
WHN
You don’t want to fix something that’s not broken.
If car is running good, no valve noise. I would leave it alone. Just use some Marvel Mystery Oil in the gas to help with the valve lubrication.
Most Model A engines will tell you if there could be a problem.
If you just are looking to play around, pull the side cover and check the lifters out. Enjoy.
Old 07-04-2018, 01:50 PM   #13
Dick Steinkamp
Dick Steinkamp's Avatar
If it was me...new motor...I'd go over the valves after 500-1000 miles. More to give me piece of mind than anything else. In addition, by that time the valve train has worn in and any initial need for adjustment would show up. I'd also be interested in hearing what the rebuilder recommended.
I have had more Model As have the valve clearance get larger as parts wear which would signal such with valve clatter, but it is also possible for the clearances to get tighter as the valve wears into the valve seat. In that case there wouldn't be any additional noise...just a loss of power as the valve eventually remains off the seat and starts to burn.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
