I hope, someone has an idea.
After changing the regulator the motor begins to stutter when it gets warm. The electrical system is a 12V system. The regulator was changed because the regulation of voltage didn't still work. I checked timing, distributor, checked and cleaned all gaps/contacts. I checked the fuel mixture. I checked sparks. The Motor is starting perfect and runs good. But when the motor gets warm after driving only 1 or 2 km, the problem begins. Checking the motor, valves work good, and I think gasket is not burned. In my opinion the intake gets very hot. when touching the throttle at carburetor it is so hot that is near to burn the fingers. I hope someone knows the problem. Thank you for ideas. |
