Old 05-14-2018, 01:28 PM   #1
37FordPickupTucson
Default 85 HP oil pressure?
Just got my '37 pickup back on the road. The 85 HP V8 (78 Series) was bored and sleeved 15-20 years ago and has .030 over pistons. It is spotless on the inside and does not burn oil. It still has the honing marks in the sleeves. I think the rebuild only has 300-400 miles on it. Compression is 90 to 110 lbs in all cylinders.
I'm running PennGrade 10W-40 partial synthetic oil. It has the high zinc and phosphorus. The stock electric oil pressure gauge in the cluster always shows 20 to 40 PSI when running. Also have an old school mechanical gauge that shows 50 PSI on cold start, then 20 PSI warmed up. Idling at stop lights the mechanical gauge shows 5 PSI while the one in the cluster shows 20 PSI.
Any caveats or recommendations?
37FordPickupTucson is offline   Reply With Quote
Old 05-14-2018, 01:34 PM   #2
Bulligen
Bulligen's Avatar
Default Re: 85 HP oil pressure?
It all sounds real good to me, there always has been a difference through mechanical and electric gauges.
Bulligen is offline   Reply With Quote
Old 05-14-2018, 02:34 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Could have the wrong sending unit. Also I wouldn't use synthetic on a fresh engine.
Old 05-14-2018, 04:09 PM   #4
petehoovie
petehoovie's Avatar
What Ken said above > "Also, I wouldn't use synthetic on a fresh engine."
Old 05-14-2018, 04:22 PM   #5
Ford Freak
Sounds ( the pressure #s ) just like the 8BA in my F1 . I been driving it for years ....F F
Ford Freak is offline   Reply With Quote
Old 05-14-2018, 07:07 PM   #6
Talkwrench
Talkwrench's Avatar
Sounds OK , do you have 77E heads? If so you should be closer to 120 lbs in the Cyls.
Are you in a cold climate? Those oils are like water, I'd just be using a 20 -50 multi grade mineral oil, changed often.
Old 05-14-2018, 08:20 PM   #7
Step-down
Step-down's Avatar
My 8BA sounds the same running ford oil filter. Some say if I removed the filter I would get a increase in oil pressure .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
