Old 04-29-2018, 08:30 PM   #1
RalphG
RalphG's Avatar
Default 52-53 Hood Bolts
No, I didn't get the 53 Merc running yet. One of my nephews (tgoff375 on youtube) stopped by today and helped me do a hood switch installing the straight 53 Merc parts car hood on the 52 driver. So I can work on straightening out the badly dented 52 hood at my leisure. It was a heavy job that I would never have accomplished myself. My question, there were flat thin washers under the hood bolts and I don't know for sure where they belong. Right under the head of the bolts? Between the hinge and the bolt?
RalphG is offline   Reply With Quote
Old 04-29-2018, 08:46 PM   #2
paul2748
paul2748's Avatar
Default Re: 52-53 Hood Bolts
The 52-56 (and maybe later) used a shoulder bolt to attached the arms to the hood. They also used "wave" washers to take up the slack on the shoulder. I assume the Merc's were the same (at least the 52-54's)
The washer wave went between the arms and the hood on my 54 Ford
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-30-2018, 01:02 AM   #3
RalphG
RalphG's Avatar
Yes, both the 52 and 53 have the shoulder bolts that hold the hood to hinges. Just flat washers though. I'm betting they probably go between the hinge and hood.
Old 04-30-2018, 04:20 PM   #4
V12Bill
V12Bill's Avatar
Their called warped washers and go between the bolt head and the hinge arms to keep them from rattling. If they are put between the hinge and the hood, they may not get over the shoulder of the bolt.
V12Bill is offline   Reply With Quote
Old 04-30-2018, 08:54 PM   #5
RalphG
RalphG's Avatar
Then maybe these are not the right washers. They are flat and resemble the brass washers found on brake banjo fittings.
