Old 04-14-2018, 03:24 PM   #1
1930.68B
1930.68B's Avatar
Default Fan belt size
I would like to know the correct size of the Model A fan belt. We are using the original generator and water pump pulleys. They are in all the Model A parts catalogs but the shipping doubles the cost of the belt.
Thanks
1930.68B is offline   Reply With Quote
Old 04-14-2018, 04:26 PM   #2
CarlG
CarlG's Avatar
Default Re: Fan belt size
Bx40
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-14-2018, 05:24 PM   #3
Synchro909
Synchro909's Avatar
Ditto B 40
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 04-14-2018, 05:32 PM   #4
wrndln
After looking up B 40 fan belts on eBay, it appears the belt is 43" in diameter. It is strange the B 40 would be 43", verses 40" like the name. Is the correct belt 43"?
Rusty Nelson
Old 04-14-2018, 06:00 PM   #5
Synchro909
Synchro909's Avatar
Rusty Nelson
That sounds weird! One time, when I was too far from another supply, I used a B43 to get me out of trouble. It was as close as I could get. To tension it, the generator was so far out to the left that the belt touched the rubber part lower water outlet near the radiator. I laid a piece of aluminium under the hose clip to prevent it wearing through and replaced the belt some 4,000 miles later.
Old 04-14-2018, 07:21 PM   #6
JOHN CT
JOHN CT's Avatar
D&D PowerDrive B40 NAPA AUTOMOTIVE Replacement Belt https://www.amazon.com/dp/B00NUQE4I0..._eQP0Ab9R5MV51
This is the belt I got from amazon. It works fine for me. It’s been on for a few years.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 04-14-2018, 10:19 PM   #7
CarlG
CarlG's Avatar
The "X" in the part number I mentioned above (post #2) is a cogged belt. The 43" that Rusty referred to in post #4 is the Outside diameter. I suspect that the "40" refers to the inside diameter, although I don't have one handy to measure to verify that.
Alaskan A's
Old 04-14-2018, 10:43 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Add things to your parts order, and buy from a dealer so you get the correct belt. The belt angle needs to be correct as well as the width and length. The belt I bought from Bratton's in the 90's for my 28 still looks like new.
Old 04-15-2018, 12:57 AM   #9
Dodge
The Napa one doesn’t fit very well. I and several othe people have had trouble with it.
The ones I have ordered from Snyders fit perfect.
Dodge is offline   Reply With Quote
Old 04-16-2018, 01:52 AM   #10
Manuel
What about B fan belts. Are they the same as the A?
Manuel in Oz
Manuel is offline   Reply With Quote
Old 04-16-2018, 05:16 PM   #11
Badpuppy
Nope - http://www.biedlers-belts.com/single...r-ii-belt.html
Old 04-17-2018, 11:48 PM   #12
Manuel
Default B Fan belt size?
The chart doesn't show makes & models BP. What diameter/size is the B belt?
Manuel in Oz
Old 04-18-2018, 05:10 PM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
To be SAFE, get the one it calls for & one slightly shorter & one slightly longer! It's a LOOOOOONG walk to PEP BOYS!
Bill Tired
"THE ASSISTANT GURU OF STUFF"
Old 04-18-2018, 05:40 PM   #14
ursus
Manuel in Oz
A and B belts are the same size and, the same as used for 1940's era Chevrolets.
Old 04-21-2018, 01:15 AM   #15
Manuel
Thanks Ursus. Never knew that....
Manuel in Oz
