04-14-2018, 08:13 AM | #1 |
1936 rumble seat back attachment
The rumble seat back cushion on my 5W coupe is attached with some homemade brackets screwed to the lid back and seat frame with sheetmetal screws (see photos). This makes the seat back loose and prone to popping off. Does anyone have any photos of how the seat back is supposed to attach to the rumble lid and what the brackets look like? I found this bracket (see photo) on a couple supplier sites. But one lists it as the upper bracket and the other lists it as the lower bracket.
04-14-2018, 09:47 AM | #2 |
Re: 1936 rumble seat back attachment
Here's somw photos that might help.
04-14-2018, 02:33 PM | #3 |
Thanks Don. The photo helps a lot. Do you know what sort of straps were used to attach the bottom? The top hangers look like they want to attach to the D nuts in the lid. My lid is missing them. Any idea where I can source those?
04-14-2018, 04:32 PM | #4 |
On the "D" nuts..check with Roy Nacewicz. The straps were thin metal and looped around the seat back spring and then screwed into the lid
More Info: The "D" nuts are actually called "clinch-on" nuts. You need (4) #10-32 "clinch-on" nuts to go with (4) #10-32 x 5/8" raven finish round head machine screws. For the bottom straps you need (2) 1/4"-20 x 3/4" raven finish round head machine screws. If the "clinch-on" nuts are missing you need (2) 1/4"-20 "clinch-on" nuts Last edited by Don Rogers; 04-14-2018 at 05:53 PM. Reason: more info |
04-14-2018, 08:00 PM | #5 |
Perfect. U-da-man! Did you get this from the 'green' book? I have a pdf version but it is not searchable, so very hard to find things.
04-14-2018, 10:22 PM | #6 |
04-15-2018, 07:49 PM | #7 |
Very good. Thank you.
