Old 04-08-2018, 12:49 PM   #1
Curtis in MA
Default Brake pills add how many degrees?
My brake arms are vertical at rest, not the 15% recommended. How many pills do I add?
Curtis in MA is offline   Reply With Quote
Old 04-08-2018, 01:04 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: Brake pills add how many degrees?
I believe the angle is 7 degrees forward of center.
Remove the brake rod, operate the lever by hand, add 2 0r 3 pills and check arm location, continue adding or removing 1 pill at a time until arm is correct.
When the correct angle is obtained, adjust brake rod length.
Ron
Ron in Quincy is offline   Reply With Quote
Old 04-08-2018, 01:04 PM   #3
Barry B./ Ma.
Barry B./ Ma.'s Avatar
(Probably not more than 2, you can get into trouble (like dragging brakes) if you add too many.
Barry B./ Ma. is offline   Reply With Quote
Old 04-08-2018, 02:08 PM   #4
1955cj5
1955cj5's Avatar
Les Andrews' section on service brake adjustment recommends 15° forward tilt on the actuating arm with all slack removed..... section 2 page 3
He first recommends a new 7 1/4" operating pin.
I used new pins and still had to add pills to get the 15° forward tilt.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-08-2018, 08:16 PM   #5
SeaSlugs
SeaSlugs's Avatar
yea i think the pins bouncing and vibrating act like a drill into the wedge. i have 2 pills on one side and 1 pill on the other to get ~15" tilt. straight up and down should be a firm lockup.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-09-2018, 08:11 AM   #6
Growley bear
I adjust my front brakes so that when the arm is vertical the wedge just comes into contact with the wedge stud. When released the arm will find its position relative to degrees.
Once the arm is vertical any more movement past center gains no mechanical advantage.
When the arm is vertical the cam should be horizontal. Any movement past this point is a drop over center and will cause the pushrod to be pushed sideways and enough arm movement will cause the pushrod to bend.
Try this:
Without the shoes installed to get in the way, install the arm w/shaft/cam and the rod and the wedge on the stud with the stud tight. Hold the arm vertical and push the wedge to the end of its movement. The space between the end of the rod and the wedge socket is the space that needs to be filled. Too many pills is not a good idea as the socket becomes very shallow and the pushrod could become displaced.
Growley bear is offline   Reply With Quote
Old 04-09-2018, 01:26 PM   #7
CarlG
CarlG's Avatar
I have one pill on one side and none on the other to achieve the 15 degree forward tilt.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-09-2018, 02:51 PM   #8
Curtis in MA
Thanks all.
What I was looking for was the amount of degrees each would add.
So if I need 15 degrees and each pill adds 5 I'd put in 3.
Otherwise I will put in one, put the wheel back together, test it, take it apart, add another, put it back together, test it, etc.
Old 04-09-2018, 03:43 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
If you need more than one then it is my belief that you need new parts. Either the operation wedge and or the operating rod are badly worn.
Old 04-09-2018, 04:01 PM   #10
JaxFLG8r
Okay. This thread is proof that there is always something to learn.
What, is a brake pill? Ed Williamson
JaxFLG8r is offline   Reply With Quote
Old 04-09-2018, 04:05 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
When your front brake pin are worn you install brake shims or "pills" to return them to the proper length so you can achieve 15° on the lever. Best to install new pins rather than install a bunch of pills. http://www.snydersantiqueauto.com/operating-pin-shims
Old 04-09-2018, 05:12 PM   #12
Curtis in MA
I added two on each side so they stayed in the cup at the top of the wedge.
If that isn't enough I will get new pins.
Thanks
Old 04-09-2018, 06:59 PM   #13
Y-Blockhead
Check the operating pin length, should be 7¼”
Old 04-09-2018, 07:03 PM   #14
Curtis in MA
They are already in the car.
Old 04-09-2018, 07:14 PM   #15
Jerry in Shasta
Jerry in Shasta's Avatar
Differant idea, I cut an old brake rod to the the correct lenght plus a 1/4". Then ground it to fine tune the lenght. No pills needed
Just my W.A.G. at the problem
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 04-09-2018, 07:44 PM   #16
Y-Blockhead
HAH!! Your too speedy. How'd it turn out?
Old 04-09-2018, 07:52 PM   #17
Curtis in MA
I still have to re-pack the bearings and put the hubs on.
